MS362 oil adjustment?
Discussion in 'Chainsaws and Power Equipment' started by Dolphus Raymond, Apr 15, 2017.
  1. Dolphus Raymond
    Dolphus Raymond
    Deep South
    Where is the adjustment screw on my MS-362? It is not on the bottom so I took off the bar cover and noticed a screw on the bar. Did not fool with it until I had more info. Thanks in advance men.
  2. MasterMech
    Should be in the same spot as it is on my 261. On the bottom.
    Barcroftb likes this.
  3. lukem
    Barcroftb and MasterMech like this.
  4. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Mine as well
  5. Dolphus Raymond
    Dolphus Raymond
    Deep South
    Ralphie, that is exactly like mine. I saw the diagram but for the life of me could not see a screw. Is that an Allen wrench you are using? The adjustment screw must be recessed I'm assuming. I'll check tomorrow
    Thanks for the input
    Ralphie Boy likes this.
  6. Ralphie Boy
    Ralphie Boy
    It's a small flat screwdriver. Dat little sucker of ah screw is stuck way down der!
  7. Dolphus Raymond
    Dolphus Raymond
    Deep South
    Found it and got it adjusted Ralphie. It is a small screw and in a very out of the way place. Oiling perfect and now if I could just find something to cut.
  8. Ralphie Boy
    Ralphie Boy
    Come on up! I've a bunch of ash to cut!
