MS290 starting issue
Discussion in 'Chainsaws and Power Equipment' started by Kimberly, Apr 10, 2016.
  1. Kimberly
    Kimberly
    The Kangaroo State
    We were using my MS290 saw today and several times trying to pull the starter rope, the rope would not pull out resulting in jerking the saw around. It is almost as if the piston was locked. However, afterwards it would pull and start and run fine. We bucked a tree we felled the other day and cut down some stumps without issue. It was just starting I had the problem and it did this enough times that I am concerned and thus seeking help.
    Woodsnwoods likes this.
  2. Eric VW
  3. thewoodlands
    thewoodlands
    I use method number 1 when I start my saws, it's on page 8.
    http://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/MS290_310_390_Manual.pdf
    Do you pull the starter rope out until you feel resistance and then pull hard.
  4. MasterMech
    These saws can do this if the rope pulley and/or the pawls become worn. Especially the pawls. Cheap and easy fix.
    Woodsnwoods, Oakman69, Horkn and 3 others like this.
  5. Kimberly
    Kimberly
    The Kangaroo State
    Yes, I do when I start the saw. My friend was using the saw today because I hurt my left arm and until it heals I can not use the saw. At one point when he started, it jerked the saw over.
  6. Kimberly
    Kimberly
    The Kangaroo State
    Yes, that is the way I start my saw as well.
  7. Kimberly
    Kimberly
    The Kangaroo State
    My friend seems convinced that it is the decompression valve; opinion on this?
  8. MasterMech
    Does not exist on an 029/MS290
  9. Kimberly
    Kimberly
    The Kangaroo State
    Thanks, so what do you think is the source of the issue?
  10. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Yup, a 50cc saw shouldn't need a decompression button..... sounds like user error.
  11. Kimberly
    Kimberly
    The Kangaroo State
    I have never had any issues starting the saw; I choke and then when it sputters, I open the choke and then pull and it starts on the first or second pull. If the saw is hot, then it needs no choking and starts without issues. I have not been starting the saw because of my hurt arm. I did witness the problem when tried to start but I am unsure how he pulls the rope.
  12. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Exactly, sounds like he was kinda..... outside his skillset.
  13. Eric VW
    My 445 has decomp, and my shoulder thanks Husky for it.....:whistle:
    :thumbs:
  14. Kimberly
    Kimberly
    The Kangaroo State
    Not at all. He knows how to start and operate saws and I saw him try to start the saw and it acting as if the piston was locked.
  15. Kimberly
    Kimberly
    The Kangaroo State
    I am going to try starting the saw myself so I can see and better describe the issue.
  16. MasterMech
    See below. Check the pawl(s). Heck, just replace them for less than 5 bucks and ten minutes of your time.
    When the pawls get worn, they do not engage the flywheel properly and can make the saw feel like it has a lot more compression than it really does.
    Woodsnwoods, CTYank, Horkn and 5 others like this.
  17. Kimberly
    Kimberly
    The Kangaroo State
    OK, will check the pawls. Thanks everyone.
    Woodsnwoods and clemsonfor like this.
  18. jon1212
    jon1212
    Utah........ugh!
    Could the muffler being carboned up cause a back pressure issue?
    Also the statement about 50cc saws and decomp valves not being necessary is a little misleading. Easier to start means more potential customers.......
  19. yooperdave
    Just buy yourself a can of Dinty Moore beef stew! Check out the footage around 00:11
  20. pantelis
    pantelis
    Europe
    I agree
