MS180 Tech. Question
Discussion in 'Chainsaws and Power Equipment' started by getstumped, Jan 21, 2015.
  1. getstumped
    getstumped
    Nebraska
    So last weekend I'm out cutting some wood and I get the 180 pinched. I only have one saw so I busted it out with my hatchet only to cut the chain in half. No biggy, I went to TSC and got a new chain only to come home and find out the gauge is .050 and I need .043. Found a local Stihl dealer and fixed that problem. My question is this: Do any of you own an MS180 and if so, have you ever upgraded to the higher gauge bar and chain? If so, was there a decrease in power? I have the 16" bar it came with and really don't want to get a shorter bar to upgrade but the .050 was definitely beefier.
    I also found a hairline crack in the bar after replacing the chain. I took the Dremel to it and fixed the gap and it seems to work fine. Any thoughts on this?
    fox9988 and HoneyFuzz like this.
  2. cnice_37
    cnice_37
    Inboard clutch is your friend there. Remove the powerhead and swap on a second bar.
    Or hang in this forum a bit longer and get a few spare saws.
    I can't comment on the .050 v .043 gauge. I can't tell a difference between .050 and .058 for whatever that is worth on a 50cc saw.
    angelo c and HoneyFuzz like this.
  3. hokie94
    hokie94
    southwest va
    I have used them a lot for carving. It will do ok with the 50 Guage picco but you will be happier with the 43 Guage on that saw it is faster and smoother in the cut. One other thing to be aware of on these saws is the muffler screen they carbon up easily and will kill the power.
    raybonz and HoneyFuzz like this.
  4. getstumped
    getstumped
    Nebraska
    Can you clean it off or just replace?
  5. cnice_37
    cnice_37
    Clean it / burn off the carbon.
    getstumped likes this.
  6. MasterMech
    Use a propane torch to hear it bright orange, once it's clear, wire brush it quick and it should be good as new.
    raybonz and getstumped like this.
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    X2. And ive had 2 Stihl 180's... Stick with .043 whether a 14" or 16 " setup ! The 180 needs every advantage it can get to keep the chain zingin thru the wood :)
    Ps... The 180 is one of my favorites btw !
    MasterMech, raybonz and getstumped like this.
  8. fox9988
    fox9988
    NW Arkansas 72717
    Is the .043 actually narrower than the .050? Other than the driver width? Does it make a narrower curf?
    MasterMech and concretegrazer like this.
  9. getstumped
    getstumped
    Nebraska
    Yes, great little saw too. Just caught me off guard when I got home and had the wrong size.
    HoneyFuzz and fox9988 like this.
  10. concretegrazer
    concretegrazer
    Southwest MO
    .043 is narrow kerf.
  11. fox9988
    fox9988
    NW Arkansas 72717
    Sorry for the derail but
    Is this true for all gauges? Does a .050 have a narrower curf than a .063?
  12. concretegrazer
    concretegrazer
    Southwest MO
    Generally no. .050, .058, .063 3/8 all wear the same cutter.
  13. fox9988
    fox9988
    NW Arkansas 72717
    Ok. That's what I thought. I forgot about narrow curf chain, never used it or seen it. Thanks.
    HoneyFuzz likes this.
  14. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Its a very important derail !! I bet a lot of guys dont know this stuff..... So i think its great to talk about !!
    LongShot, concretegrazer and fox9988 like this.
  15. prell 73
    prell 73
    ia
    I switch to the .050 chain an bar on my 170 and had no differ in power.
    concretegrazer likes this.
  16. jetjr
    jetjr
    Pa/Md line
    I recommend grabbing an extra bar and chain. Then you can just take the power head off and cut the other bar out and keep on:saw::dex:
    prell 73 likes this.
  17. getstumped
    getstumped
    Nebraska
    Took me a bit to realize what you guys were talking about. Lightbulb moment!!! I'd love another saw for sure, but this is way cheaper for the short term. Thanks Gents!!!
    LongShot, cnice_37, jetjr and 2 others like this.
  18. jetjr
    jetjr
    Pa/Md line
    I have 2 saws and still carry an extra bar for the bugger saw. Just never know.
  19. concretegrazer
    concretegrazer
    Southwest MO
    Sounds like you need 3 saws.;)
    jetjr, LongShot and MasterMech like this.
