Mower Issue
Discussion in 'Everything Else (off topic)' started by eatonpcat, Aug 5, 2025 at 7:54 AM.
  1. eatonpcat
    Need some help.
    Exmark Lazer Z - Kohler 23 HP Kohler
    Mower starts, but sounds like it may be running on only one cylinder. It will drive, but bog down if I give it more gas.
    Blades will engage, but the engine bogs, thought maybe bad coil on one side. Strange thing is that if I drive it from the barn to the front of the house and let it sit for a while it starts and seems to be running on both cylinders, blades engage, and I can cut the grass. Maybe a fuel delivery issue?
    My mechanical skills (actually all my skills) are minimal, but I don't think the coil would start working again.
    Replaced plugs, fuel filter and air filter.
    Any thoughts, although I am sure I will be making an appointment soon? Problem is shops usually take a month to get you in.
  2. T.Jeff Veal
    Just kidding, brother.
    Hope it's an easy fix.
    Horkn, brenndatomu, MikeInMa and 3 others like this.
  3. eatonpcat
    That would definitely fix it...Since you're heading North in a couple months, throw it on your trailer, and Thanks, I will take it!!
  4. RCBS
    RCBS
    Over here
    Is it completely fine once hot? Seems like coils are usually opposite and mess up when once they get hot. Unsure if autozone or the like can test a coil for you? If it's fuel delivery I would look at the pump. Assume it's a diaphragm unit probably bolted to the side of the engine somewhere. A little black box with several hoses coming and going.
    Spitball....is your fuel tank cap venting proper? Any chance of water in your fuel?
    Horkn, brenndatomu, Ronaldo and 2 others like this.
  5. eatonpcat
    Don't think there is water in the fuel, but who knows (probably put 10 or 15 gallons of new gas in since this problem started). I will check the vent on the cap.
    Thanks for the advice.
  6. JD Guy
    JD Guy
    Upstate SC
    Like others just spitballing. I had a diesel Massey Ferguson 240 a number of years ago and it always ran perfectly. Suddenly it would start to bog down and eventually the engine would stall out. Found that there was some crud in the tank that was blocking fuel to the sediment bowl.drained it out and all was well. This was a fairly old tractor so that had some bearing on it too.
  7. eatonpcat
  8. lukem
    Unplug spark plug wire on each side and see if it gets worse or stays the same.
  9. eatonpcat
    Thanks lukem
    If I get shocked I will blame you! LOL
  10. lukem
    That's what insulated pliers, wives, and children are for.
    JoeyD, Horkn, eatonpcat and 1 other person like this.
  11. brenndatomu
    Wow...weird. My first thought was a bad plug, but since you already took care of that... second guess is bad fuel, or a fuel delivery issue...if yours has the fuel pump attached to the valve cover, Kohler had some issues with some of those too.
    Ignition coils usually fail hot, not cold.
    Not a ton of help I guess... I suppose I'd drain the fuel, put in new, go from there...maybe look for mouse chewed wires/hoses, since there is a history there...:D
    Jeffrey Svoboda, Horkn and eatonpcat like this.
  12. eatonpcat
    Mouse is a good possibility, I will take the shroud off and see if I can see something chewed.
    Thanks Dave....
    I drove through Orrville on Sunday. Mighty fancy Ford Dealer. Think it was Whites Ford?
    brenndatomu and Horkn like this.
  13. Jeffrey Svoboda
    Jeffrey Svoboda
    Coils usually fail when hot and can come back to life once they cool off.
    I'd do like lukem suggested, when the problem is present pull each coil wire and see if the problem gets worse or is uneffected. Obviously reconnect the first coil wire before disconnecting the second. In his defense, he didn't tell you to use your hand. ;)
    eatonpcat, brenndatomu and Horkn like this.
  14. Horkn
    Yeah, usually coils fail when hot. I wouldn't doubt that that's gunk in the filter/ fuel tank. Do some digging and let us know what you find.
    eatonpcat and brenndatomu like this.
  15. ironpony
    ironpony
    Mid Ohio
    Drop of water or sediment in the carb bowl drop it and clean it.
    eatonpcat likes this.
  16. eatonpcat
    Jeffrey Svoboda likes this.
