more heat out of the hot blast furnaces.
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Zachb91, Feb 3, 2017.
  1. Zachb91
    Zachb91
    Southwest indiana
    Mines only puts about 65 to 70 degree heat out the duct work. Granted it is in a shed attached to my house uninsulated would insulation help it put out more heat?
    Sent from my SM-S906L using Tapatalk
    blacksmith likes this.
  2. Zachb91
    Zachb91
    Southwest indiana
    Would it being ran in flex duct make a difference mind you all this was free so I just put it in the back room. Eventually I'll put it in the basement.
  3. chris
    chris
    SE WI
    What is the return intake being fed by? from in the house or just outside air? Best way to run that is with the return hooked to cold air return of the house. Pulling outside air and forcing that into the house isn't going to work to well- un-insulated duck work -just heating the outside.
    concretegrazer likes this.
  4. Zachb91
    Zachb91
    Southwest indiana
    It's pulling the air from outside around the stove. I'm using insulated flex duct
  5. fox9988
    fox9988
    NW Arkansas 72717
    This is super inefficient.
  6. Zachb91
    Zachb91
    Southwest indiana
    Only place I got right now. Gonna try an save the money an put it in the basement. This year
    fox9988 likes this.
  7. chris
    chris
    SE WI
    When you move it to basement hook the cold air return system of the home to the heat ex-changer intake. not doing that will give very poor preformance although world better than your current set up. Likely have to make a connection box of some type to do that. You will also need to add a back draft damper to the hot side between the reg furnace and the hot blast. Should be able to find a manual on line for the hot blast.
  8. brenndatomu
    So there is no return air duct hooked up? Yeah that will drop your air temps for sure. Get a return duct on there, it needs to be same size or preferably bigger than the supply duct. So if you have (2) 8" supply ducts. that's ~100 sq inches, so (1) 12" return duct would work (113 sq in.) And yeah, insulating that shed would help.
  9. Zachb91
    Zachb91
    Southwest indiana
    Ok I'll try that.
  10. Zachb91
    Zachb91
    Southwest indiana
    Ok right now the I have 1 duct blocked off put plan on running both down in to the basement. Then running 1 to the kids room and 1 to are bedroom.
  11. Zachb91
    Zachb91
    Southwest indiana
    Ignore the mess but here's my setup right now.
  12. brenndatomu
    Don't load more than about half a load of wood in it with using only one supply duct, you'll get things glowing red inside...literally...not good! There is just not enough air flow there to cool the firebox. You'll get much more heat out of it by using both ducts too...and hooking up the return air as mentioned earlier.
    Also, if you can get at least inside the window before going to flex, it would be really good...you're actually not supposed to use flex on the supply duct of a solid fuel furnace at all...but if you can get 10-15' from the furnace, it would lessen the chance of melting it...which is going to blow toxic fumes all through your house, also not good!
    Saving money with wood heat is not worth burning the house down over, or making someone sick (or worse)!
    Locust Post likes this.
  13. Zachb91
    Zachb91
    Southwest indiana
    My plan is to run both ducts down out of steel duct work just gotta save up the money.
