Moist.......
Discussion in 'The Wood Pile' started by SD Steve, Aug 1, 2020.
  1. SD Steve
    SD Steve
    South Dakota
    Ok, so I dont have a moisture meter. I'm sure that I can just do a Google search and find one. But, I really want to know which one out there is a good reliable meter. Something I can use for at least a few years.
    Now that I finally have wood piled up all over the place.
    20200801_134608.jpg 20200801_134620.jpg this stack is all pines/spruce but mostly the ponderosa I cut down 20200801_134810.jpg 20200801_134819.jpg my mostly cottonwood holz hausen
    20200801_134904.jpg this stack in my garage is 3 rows deep.
    This is my stack over at my parents house, they just moved from CA to Texas, they are snow birds. But this here is my stack here in South Dakota.
    I'm starting to get confused as to which stacks are dryer than others.
    What do you guys, and gals, use??
  2. wood and coal burner
    Quakertown,PA
    I use one of those inexpensive volt ohm meters from Harbor Freight. Sharpen or file the leads real sharp, stick in the ends of the wood and measure the resistance (ohms). Set on the highest setting the wood should be at least 2M to 3M ohms but I usually shoot for 4M that way it will always be less than 20% moisture.
  3. SD Steve
    SD Steve
    South Dakota
    How in the world did you ever figure that out? I've been using multimeters for almost 25 years and have never heard of using it like that. But hey if it works.
    Just because I like talking about them, I just bought a new meter made by "Fieldpiece" the SC 640. I had my trusty SC76 for well over 10 years but it began to read capacitance (microfarads) wrong. Fieldpiece told me they could repair it but it was still way out of spec and no longer supported.
  4. Eric VW
    I have a General from Lowe’s- $25 or so. Works great.
    Remember to resplit and check on fresh wood- ends dry out faster than internally.
    Any of the $10-15 Chinese MM’s on Amazon will work fine.
    Horkn loves the one he has that BT’s to his phone.
  5. LordOfTheFlies
    LordOfTheFlies
    NY
    I use this General one. $22.84 on Amazon. Works great.
  6. Horkn
    I have a couple, but the Ryobi phoneworx one I have is pretty slick. It uses the camera and the screen and memory of a smartphone ( as long as it has a 3.5 mm headphone jack). It's not BT, but that would be extra slick, and probably make it a little more$ than the corded one now. You can store pics and it will take outside weather conditions and sure them on the files too.
    To be honest, the pinless Dr Meter MM my wife got me works at least as accurately as the Ryobi, and it's even more convenient, as it doesn't require a phone. As far as pin vs pinless, the pinless ones are typically more accurate, but the one I have is as accurate as ones that cost around $500. So you'd have to compare apples to apples.
    It doesn't and can't record all the data, but I don't need it to do that either.:cool:
  7. ErikR
    ErikR
    Deep in the woods near Cable, WI
    I just use the inexpensive one from a local Harbor Freight... like this...
    It's good enough for me. Most of my wood is so old that I don't have to worry if it's dry enough.
  8. buZZsaw BRAD
    I had one but gave it to my friend and have been wanting to get another.
  9. billb3
    General from Lowes.
    I find if you split a split open fresh you don't have to jam the points way in (deep) like some claim.
  10. T.Jeff Veal
    X2... this is the one I have.
