Minion method pork butt
Discussion in 'The Smokehouse' started by tuneighty, Jun 30, 2015.
  1. tuneighty
    tuneighty
    South Central PA
    Testing a modified minion method in the big chicken cooker. Butt went on at 630pm. She is holding steady at 260°. About 1/3 through the coal.
    Eric VW, TurboDiesel and Horkn like this.
  2. tuneighty
    tuneighty
    South Central PA
    That's a water pan in the center..
    Eric VW and Horkn like this.
  3. tuneighty
    tuneighty
    South Central PA
    And a few pieces of mulberry.
  4. Horkn
    You smoke with bark? I've always removed bark for any smoking as I've been told it gives a bad flavor.
    Eric VW likes this.
  5. tuneighty
    tuneighty
    South Central PA
    I don't mind, though I don't think much of the bark will burn in this set up. However I don't debark it if we use the firebox either.
  6. Elderthewelder
    Elderthewelder
    Washington State
    i dont see any pork butt
    basod and Eric VW like this.
  7. tuneighty
    tuneighty
    South Central PA
    That will have to wait a bit. If your lookin you ain't cookin.
    Eric VW likes this.
  8. tuneighty
    tuneighty
    South Central PA
    Well... The cooker is still doing well. (Maybe another hour of i let it go) But the cook is Beat, into the oven for the night.
    Normally using it as a stick burner the longest we can go is 4 hours. I am calling it a success, but needs tweaked.
    basod, Chvymn99, Eric VW and 2 others like this.
  9. TurboDiesel
    Looks good tune:yes:
    Horkn and Eric VW like this.
  10. Paul bunion
    Paul bunion
    I always run my WSM by the Minion method, that it light it on top and let it burn down. I easily get overnight burns, only need refueling at the 16th to 20th hour when running butts long.
    TurboDiesel likes this.
  11. TurboDiesel
    how much charcoal does it take to run that long?
  12. tuneighty
    tuneighty
    South Central PA
    Yes, I learned the minion method with my UBS, but it has since been retired. So I am trying it on a big stick burner (we can fit 27 chicken halves or 15 racks of ribs on it.)
    TurboDiesel - I used to use 7-9 lbs of charcoal roughly, and could consistently get a 16-17 hour burn.
    Elderthewelder likes this.
  13. tuneighty
    tuneighty
    South Central PA
    This is 25 halves on the same cooker from Saturday. Cooking in the rain ... what joy :)
    The smoke box is on the back center, it also has charcoal pans and propane for inside the cook box.
    fuelrod, savemoney, basod and 3 others like this.
  14. cus_deluxe
    cus_deluxe
    Northern Michigan
    thats dedication! Nice rig dude
    tuneighty and TurboDiesel like this.
  15. basod
    basod
    Mount Cheaha AL
    Nice name and avatar:thumbs:
    A late welcome aboard.
    cus_deluxe and TurboDiesel like this.
  16. basod
    basod
    Mount Cheaha AL
    Trying to hold temps in the rain is a PITA
    I guess the minion method is lighting a line of charcoal slowly from one end to another with a water pan for humidity?
  17. Elderthewelder
    Elderthewelder
    Washington State
    basically yeah. I had to look it up though
    basod likes this.
  18. basod
    basod
    Mount Cheaha AL
    that's what I thought - vaguely remember reading about it years ago.
    It's much more likely to work in larger tighter cookers with even inflow of fresh air.
  19. TurboDiesel
    Here is a good vid on the minion method with baffles if you never heard of it. pretty good control of the burn and helps to extend the burn time
    basod and tuneighty like this.
