Mid season chimney brush
Discussion in 'Modern EPA Stoves and Fireplaces' started by Pricey106, Feb 16, 2023.
  1. Pricey106
    Pricey106
    Northeast PA
    Just did my February chimney cleaning. It was actually pretty clean. I usually do it in August to prepare for burning season, then halfway through. This time I had the least amount of creasote that I have ever had. Most other times it was almost double what is in the picture. Seasoned wood really does pay off. 20230215_173639.jpg 20230215_173643.jpg
  2. Deererainman
    Deererainman
    Union City Ky
    About 3 years ago I started doing the same. I purchased a moisture meter about the same time. The Jotul F500 and my chimney are much happier with 15% ish moisture wood. This forum is a great asset too. I thought a years worth of time was plenty for oak, found out the hard way, it takes more time in the bigger splits I was burning. My splits now are smaller and everything is a minimum of 2years in the woodpile, sometimes more.
  3. Locust Post
    Never hurts to be safe. I was up on the roof awhile back and it did not warrant a brush, as you said dry wood helps.
