Metal Shed Roof is Bad Idea
Discussion in 'The Wood Pile' started by Dstrick, Nov 24, 2019.
  1. Dstrick
    Dstrick
    Maple Valley, Washington
    I am replacing the metal roof on my shed because it rains condensation every night. My first year with it molded the center of a 6 cord stack. The shed is empty at the moment so it’s a good time to do it. I recommend never using metal roofing on a wood shed. It’s cheap and easy but not effective for keeping wood dry. I am in western Washington.
    FatBoy85, M2theB, Marvin and 16 others like this.
  2. Midwinter
    I haven't had that problem, but, I live in a less humid climate.
  3. Nitrodave
    Nitrodave
    Grayling Mi.
    Weird... lots of metal roofed structures around here. I would guess poor ventilation more of a concern.
    Husky Man, FatBoy85, M2theB and 11 others like this.
  4. Horkn
    That's odd. How close was the roof to the wood stack? Also what where the dimensions of the stack? Was it a square or longer? I ask because lack of airflow might be the problem.
  5. Backwoods Savage
    Perhaps this could be a problem in some areas and for sure how it is built can make a terrific difference. For example, those stringers perhaps should run in the other direction to allow front to back air circulation.
    There indeed can be some condensation with steel roofs and we occasionally get some in the colder months but very, very little. But this is only in the metal sheds and no air circulation as in the colder weather we don't even have windows open and for sure not the doors.
    But in our outdoor stacks, we've never had a problem.
    Christmas-2008d.JPG Getting wood for winter.JPG Wood-3-4-10d.JPG Woodpile-2 2014.JPG
    Stephiedoll, MFMc., FatBoy85 and 24 others like this.
  6. Kimberly
    Kimberly
    The Kangaroo State
    I can see a situation with lots of green wood drying under the metal roof; the warm moist air raising from the stacks hits the cold metal roof and condensing and dripping back to the wood that one is trying to dry. Maybe a higher pitch would help the condensed moisture to run to the edge and drip off. So what are you going to replace it with? You would probably have the same problem with the plastic or fibreglass roof panels.
  7. Dstrick
    Dstrick
    The pictures of the shed show it empty, wide open and still dripping. The could be no ventilation issue at this time.
    Western Washington is a very mild climate. We sit at and above freezing all winter here. It does not rain condensation when frozen. Ideally a shake roof, but wood deck comp shingle is what it needs.
    Wood deck and asphalt shingle.
  8. Dstrick
    Dstrick
    The shed is just a roof. I don’t think it’s an airflow problem. It is two 12’ x 12’ bays with a 1:6 pitch.
  9. In the Pines
    In the Pines
    it will still condensate, the wood will just absorb the moisture more until it can't and will mold/rot.
    This is why there are vents in roofs, ridge cap/gable vents and those square vents I can't think of the name right now.
    I'm not sure how you could cut the condensation down on that though, it's open all the way around.
    Is it in the shade all the time? no wind getting to it?
  10. Kubota
    Kubota
    CT
    Wow, interesting. I put up my first metal rood shed this spring, filled it w. 15 cords of wood and have nothing but phenomenal things to say about it. It is wide open though, no sides.
    I would think climate must make all the difference.
  11. Dstrick
    Dstrick
    It is west facing, open to prevailing breeze. Full sun from noon on.
  12. Dstrick
    Dstrick
    It must be. Everyone that loves them is in the northeast. I could then say that metal roof wood sheds are not so good in the western Washington climate.
  13. moresnow
    moresnow
    My neighbor built a greenhouse that looks like a perfect wood shed, storage/kiln setup. All clear corrugated poly panels from Menards. Cheap. Stays Africa hot inside whenever there is a hint of sun. I'll be trying these. I've never seen any condensation inside his structure. May be worth a thought.
  14. In the Pines
    In the Pines
    I'd be half tempted to put a weather station in it to log humidity and wind speed to see what is going on.
    My tarps get condensation on them too. Which I blame on the ground being damp and the sides of the tarp being too low to let enough air thru.
    I am now trying a double pallet situation where I stack 2 pallets and than stack wood on top to see if that allows more air thru the bottom.
  15. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Interesting...
    Like said above, climate has a lot to do with it. My pole barn sweats when the temps swing, but not to where there’s water dripping.
    What fasteners did you use? Screws w neoprene washers? No purlins?
  16. Dstrick
    Dstrick
    I like the way you're thinking but I'm not going to go all psychrometric on my wood shed.
  17. buZZsaw BRAD
    Regardless of roof covering, make sure you have good ventilation. Ive seen what that can do on residential structures in attics from many years of roofing.
  18. billb3
    Less mass and temp differential by using lath boards would probably work.
    I don't think the problem there is the metal roofing.
  19. In the Pines
    In the Pines
    The odd chance it snows, I don't know if lathe board can support any kind of load. Agree on the metal not being the problem though.
    I did some modular homes with 1x3's for rafters, they couldn't support my weight when I was just bones and clothes.
    Snapped one right in half and ended up in their bedroom.. oops..
  20. metalcuttr
    metalcuttr
    western WA
    I would think the metal would be fine if you sheathed the roof first with cdx plywood. Put down a layer of 30lb felt, Tyvek or Ice and Water Shield and metal on top. This would keep a barrier between the cold underside of the metal and the water vapor from the wood. Would still have to insure ventilation by having open relatively open sides and leave some space between the stack and the structural beams.
