Men's Tools explained
Discussion in 'Everything Else (off topic)' started by Jack Straw, Dec 9, 2016.
  1. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Mens Tools Explained
    DRILL PRESS:
    A tall upright machine useful for suddenly snatching flat metal bar stock
    out of your hands so that it smacks you in the chest and flings your beer
    across the room, denting the freshly-painted project which you had carefully
    set in the corner where nothing could get to it.
    WIRE WHEEL:
    Cleans paint off bolts and then throws them somewhere under the workbench
    with the speed of light. Also removes fingerprints and hard-earned calluses
    from fingers in about the time it takes you to say, "Oh, sh*t!"
    SKILL SAW:
    A portable cutting tool used to make studs too short.
    PLIERS:
    Used to round off bolt heads. Sometimes used in the creation of
    blood-blisters.
    BELT SANDER:
    An electric sanding tool commonly used to convert minor touch-up jobs
    into major refinishing jobs.
    HACKSAW:
    One of a family of cutting tools built on the Ouija board principle. It
    transforms human energy into a crooked, unpredictable motion, and the more
    you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS:
    Generally used after pliers to completely round off bolt heads. If nothing
    else is available, they can also be used to transfer intense welding heat to
    the palm of your hand.
    OXYACETYLENE TORCH:
    Used almost entirely for lighting various flammable objects in your shop on
    fire. Also handy for igniting the grease inside the wheel hub out of which
    you want to remove a bearing race.
    TABLE SAW:
    A large stationary power tool commonly used to launch wood projectiles for
    testing wall integrity.
    HYDRAULIC FLOOR JACK:
    Used for lowering an automobile to the ground after you have installed your
    new brake shoes, trapping the jack handle firmly under the bumper.
    BAND SAW:
    A large stationary power saw primarily used by most shops to cut good
    aluminum sheet into smaller pieces that more easily fit into the trash can
    after you cut on the inside of the line instead of the outside edge.
    TWO-TON ENGINE HOIST:
    A tool for testing the maximum tensile strength of everything you forgot
    to disconnect.
    PHILLIPS SCREWDRIVER:
    Normally used to stab the vacuum seals under lids or for opening old-style
    paper-and-tin oil cans and splashing oil on your shirt; but can also be
    used, as the name implies, to strip out Phillips screw heads.
    STRAIGHT SCREWDRIVER:
    A tool for opening paint cans. Sometimes used to convert common slotted
    screws into non-removable screws and butchering your palms.
    PRY BAR:
    A tool used to crumple the metal surrounding that clip or bracket you needed
    to remove in order to replace a 50 cent part.
    HOSE CUTTER:
    A tool used to make hoses too short.
    HAMMER:
    Originally employed as a weapon of war, the hammer nowadays is used as a
    kind of divining rod to locate the most expensive parts adjacent to the
    object we are trying to hit.
    UTILITY KNIFE:
    Used to open and slice through the contents of cardboard cartons delivered
    to your front door; works particularly well on contents such as seats,
    vinyl records, liquids in plastic bottles, collector magazines, refund
    checks, and rubber or plastic parts. Especially useful for slicing work
    clothes, but only while in use.
    Son of a b*tch TOOL:
    Any handy tool that you grab and throw across the garage while yelling, "Son
    of a b*tch" at the top of your lungs. It is also, most often, the next tool
    that you will need.
  2. swags
    swags Moderator
    Good laugh, thanks for posting that
  3. Elvisss222
    Elvisss222
    Eastern PA 19465
  4. Backwoods Savage
    Very well describes many tools that we have on hand. :whistle:
    colin.p, Thor, Eric VW and 1 other person like this.
  5. Gasifier
    :rofl: :lol::thumbs: I'll have to share this with my brothers and sisters.
    gbreda, Thor, Eric VW and 2 others like this.
  6. Rowerwet
    Rowerwet
    Seacoast NH/MA
    FLASHLIGHT - a device used to store dead batteries
  7. rottiman
  8. rottiman
  9. Chris F
    Chris F
    Micksburg, Ontario
    I can relate to the pliers and blood blisters :emb:
    Backwoods Savage, basod, Thor and 2 others like this.
  10. Stinny
  11. DaveGunter
    DaveGunter
    First read the thread title and thought maybe scavenger was trolling for a mate again.
    colin.p, brenndatomu, milleo and 6 others like this.
  12. Eric VW
    Great, hilarious stuff Jack Straw :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    :thumbs:
    And so true on soooo many different occasions :headbang:
  13. scavenger
    scavenger
    saybrook township ohio
    I don't know how you guys walk around with those things....:picard:
    Backwoods Savage, Thor and Jack Straw like this.
  14. Jack Straw
    Jack Straw
    Ok Elaine :rofl: :lol:
    Backwoods Savage, gbreda and Thor like this.
  15. gbreda
    gbreda
    NH
    Finally, someone who knows what these tools are really used for
    I hate slotted screws and so do my palms, knuckles and especially that fleshy area between your thumb and forefinger :rofl: :lol:
    colin.p, Eric VW, Jack Straw and 3 others like this.
  16. Jack Straw
    Jack Straw
    Have you ever put the tip of the screw gun into your hand? :faint:
  17. rottiman
    Yes.........................:emb:
    Stinny and Eric VW like this.
  18. gbreda
    gbreda
    NH
    Not yet but I have missed with a hammer and really did see stars just like in a cartoon :doh:
    Eric VW likes this.
  19. Eric VW
    Palm and fingernail bed...thru the fingernail first :headbang:
    rottiman likes this.
  20. bogieb
    Gotta admit I looked only because of the title :whistle:
    Lots of truths there - funny, but true.
    My hand apparently has a better survival instinct than the screw gun has aim - not that it hasn't tried really hard . . .
    wildwest, Jack Straw and Eric VW like this.
