Member Designed Saw Is Done
Discussion in 'Chainsaws and Power Equipment' started by KilliansRedLeo, Aug 13, 2014.
  1. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Well almost, just waiting on one lousy HVA screw to hold the filter on. I have been using a used one, waiting for new OEM! I will post pics/vid tomorrow.
  2. milleo
    milleo
    Maine
    :popcorn:
    Oliver1655 likes this.
  3. splitoak
    splitoak
    jefferson co wv
    :popcorn:.....is this a bid saw?
    Chvymn99 likes this.
  4. Chvymn99
  5. bryanr2
    bryanr2
    :drool::popcorn:
    If this is the bid saw.... dont sell it during the day when some of us are away from the Computer. Wait til the evening.:yes:
  6. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Yes, it is the member designed saw, the bidding will be from October the 3rd until October 13. Have at it boys.
  7. splitoak
    splitoak
    jefferson co wv
    Watin fer pics an specs;)
  8. mdavlee
    mdavlee
    Do we want to go ahead and port it now so it's done when the bidding starts or wait and see if the winner wants a ported saw?
  9. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Mike, if it were up to me, I'd be sending it off you yesterday. Unfortuntely it is not. We'll just have to wait until the winner has run the saw and give them room to make their own decision.
  10. clemsonfor
    Not even a peek?
    Kevin Smith likes this.
  11. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Pictures and specs in just a bit. I have customers' saws to finish up, pack and ship. Besides it is raining 'big time' here!
    KRL
  12. DexterDay
    DexterDay Administrator
    Northeast Oh
  13. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Firewood Hoarders Club members designed this saw by selecting (by poll) all of the major components of the build. It is essentially a brand new saw, using all OEM components except the muffler and the air filter.
    The saw is a ground up build of the Husqvarna 372XPW (74.6cc) using new OEM or new old stock OEM parts
    · New OEM crankcase
    · New OEM crankshaft, bearings, gaskets and seals
    · New OEM 51.4mm 74.6cc cylinder and piston assembled with base gasket Per Mdavlee for possible WP (member selected)
    · New OEM clutch
    · New Walbro HDA-12-1(B) carburetor with limiters removed (member selected)
    · New OEM HD intake tract (member selected)
    · New AM HD air filter
    · OEM unlimited coil
    · New OEM Tank/handle unit, starter, clutch cover, top cover, HD filter cover and inner/outer felling dogs
    · New OEM AV mounts and controls
    · New OEM half-wrap top handle (member selected)
    · Dual port/tuned pipe AM modified muffler (member selected)
    Assembly process was carried out using HVA approved tools, methods and specifications including all fasteners installed to factory torque standards.
    Saw has approximately 20 minutes run time for tuning purposes. The saw is currently tuned for no ethanol fuel at 50:1. (I HIGHLY recommend retuning for your location and for extended life running 32:1).
    Saw passed pressure vacuum test during assembly and is currently producing 148 PSI compression. However the compression will go up 5-7 PSI as the saw breaks in.
    Pictures of the completed saw will follow shortly, and just to satisfy Fuzz I'll put a bar and chain on it. Ignore any brown stains on the saw as they will probably be blood, Fuzz will clean them off for you!
  14. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    OK, here are the pictures, in case you didn't have time or energy to look at all the others that were posted.
  15. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    And here are some more.
  16. mdavlee
    mdavlee
    Looks good.
  17. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    And before someone asks the pulse line is Viton and of better quality than the factory line much thicker wall and more stiff to resist kinks. It does not come in black! It is Dolmar pulse/fuel line for the PS-421 and is sold by the meter about 9-11$.
  18. jchin
    jchin
    Oh my..........................................................................
  19. DexterDay
    Northeast Oh
    That's what I am talking about Jack!!
    Looks like it will be a bidding war!! :thumbs:
  20. DexterDay
    Northeast Oh
