Maxima Castor 927 oil?
Discussion in 'Chainsaws and Power Equipment' started by mike bayerl, Oct 30, 2020.
  1. mike bayerl
    mike bayerl
    Anybody ever tried this 2-stroke oil? The Wood Wolverine I was at the local bike shop picking up some other stuff and saw it on the shelf, so I picked up a pint to try it out. I'm sensitive to the smell of 2-stroke oils and I run a lot through my ported saws, like 32:1.
    T.Jeff Veal, Horkn, mat60 and 5 others like this.
  2. brenndatomu
    Mmm...bean oil...love that smell...:thumbs:
    I've never used it that much, but I've heard that it doesn't do very well in cold weather...separates or something...and you want to only mix up as much as you will use right away...doesn't store well or something...not sure what the problem is, just going by what I always heard from the motocross guys...
    T.Jeff Veal, Horkn, mat60 and 6 others like this.
  3. The Wood Wolverine
    Matter of fact, I just got through a quart of it myself. I personally didn’t care for the smell.
    And being a bike oil, it very well may gum up your saw at a heavy ratio. I know Klotz R50 does, but do I love the smell of it!
    I recently went back to my local Stihl/Echo dealer and picked up a 6 pack of Red Armor. I really like that erl.
  4. mike bayerl
    mike bayerl
    Thanks! Your opinion/experience is highly respected !
    T.Jeff Veal, Horkn, mat60 and 3 others like this.
  5. mike bayerl
    mike bayerl
    I'll probably mix it closer to 40:1
  6. brenndatomu
    That was a problem on power valve engines too...
  7. The Wood Wolverine
    And heavy ratio I mean 40/1 and more. Tune was good on this:
    Moral of the story, use caution when using bike oils.
  8. cnice_37
    cnice_37
    All right, oil thread!!
    billb3, Nixon, T.Jeff Veal and 7 others like this.
  9. brenndatomu
    Yeah, those never end in a peeing contest, huh?! :rofl: :lol:
    T.Jeff Veal, Horkn, mat60 and 4 others like this.
  10. The Wood Wolverine
    I think oil threads can be useful, until said peeing match starts. I'm just sharin' my own experience. :yes:
    T.Jeff Veal, Horkn, mat60 and 8 others like this.
  11. tamarack
    tamarack
    paulina oregon
    Echo red armour seems like good oil. I switched to that. I was using the synthetic stihl oil.
    Nixon, T.Jeff Veal, Horkn and 6 others like this.
  12. mike bayerl
    mike bayerl
    Thanks Jason. I'm of the camp that just about any decent 2-stroke oil should be fine as long as it's mixed correct and carb is tuned. I was just curious to run some bean oil since I'm very hit-or-miss with smell of oils. This was definitely not a "what's the best oil?" thread, just asking the hive mind for experiences.
    T.Jeff Veal, mat60, M2theB and 5 others like this.
  13. The Wood Wolverine
    Just have to be cautious with oils intended for motorcycle use. Some/most don't burn complete with the relatively low load of a chainsaw. Milling is a different story, the high heat gets it done in that application. Just don't run it all the time, or if you do, pull the top end to do an inspection to see exactly what it's leaving behind. I ran the Klotz for a good while because I love the smell, then I was properly educated on it and after pulling apart the Jonsey-red, I saw what I pictured above. Goo! That saw had proper tune too (and @ 40/1). If you are sensitive to smell at all, check out the Red Armor. I find it very very acceptable in that department. I used the Husky XP oil forever till I started milling. It about knocked me out with fumes, that's what led me to Klotz and then to RA for it's ability to clean up said goo.
    Nixon, T.Jeff Veal, mat60 and 6 others like this.
  14. Yawner
    Yawner
    Louisiana
    I, too, am sensitive to exhaust fumes/oil smell. Last year, I switched to Echo Red Armor. It turns the gas red and I like that for ease of identifying if need be. As for smell, I really screwed up recently and poured bar oil into the fuel mix side of my dual fuel/oil can. I poured it all out but residue is left and my saws are smoking like crazy and stink, lol. Makes my eyes burn. I mix at 40:1 but I wonder what the residue bar oil makes it. I have been thinking of diluting it some with some 50:1 or whatever to just make it better. I assume it won't hurt my saws.
  15. bang
    bang
    South central Indiana
    Castor is very good for water cooled and engines that are disassembled/ rebuilt frequently. The carbon buildup is significant in aircooled engines that have higher head temperature.
    T.Jeff Veal, mat60, M2theB and 4 others like this.
  16. mike bayerl
    mike bayerl
    Picked up a 6-pack of the 5.2 oz (2 gal. size) of Echo Red Armor for $15 today. I'll mix some up with fresh no-E gas for next weekend's cutting. If I like it, that should last me a very long time.
  17. Mag Craft
    Mag Craft
    South East Wyoming
    I run all my 2 stroke engines at 32 to 1. I have tried some motorcycle racing oil but I mainly like oils that are 100% synthetic. I have used Amsoil and Stihl and Klotz and some others I cannot remember the name right now. I happen to think the 32 to1 is better for the bottom end of the engine and a good 100% synthetic oil will not gum up.
    As far as castor oil goes I have heard that it can really gum up but have never experienced it myself.
    T.Jeff Veal, mat60, M2theB and 3 others like this.
  18. huskihl
    huskihl
    Amsoil Dominator, Red Armor, Schaeffers, and Golden Spectro are the top 4 in a lean ratio test by an OPE member. They were all relatively clean inside also.
    Can definitely smell Amsoil, sort of addictive. Didn’t notice much smell with Red Armor or Schaeffers. Never tried Golden Spectro
  19. The Wood Wolverine
    Klotz R50. Good 100% synthetic oil. It’ll gum up any saw that isn’t millin. That’s what caused pics above. This saw had a tune that wasn’t fat either:
    Tear down was after that vid.
    huskihl Schaeffers meant for air cooled engines? :whistle:
    M2theB, T.Jeff Veal, Horkn and 2 others like this.
  20. huskihl
    huskihl
    Nope. Rated TCW3. And still ahead of Saber, xp+, motul 800, ultra....
    The list goes on and on
    M2theB, T.Jeff Veal and brenndatomu like this.
