Material for concrete forms.
Discussion in 'The DIY Room' started by Marshel54, Jun 23, 2019.
  1. Marshel54
    Marshel54
    I have a barn that was built about 100 years ago. The bottom/foundation is built out of concrete and field stone. It is eroding away. It is about 2' from floor to sill.
    I was thinking about making forms and pouring concrete. Looking to go on the cheap.
    Could I use 7/16 OSB sheathing or subflooring? It would save a bunch of money over using plywood.
    I am open to any other suggestions.
  2. Chaz
    Chaz
    Southwestern NY
    With enough bracing I don't see why not.
    But I'm no contractor, so there's that.
    :whistle:
  3. brenndatomu
    Yeah you'll hafta brace the heck out of it, so that might eat up your savings. Plus the OSB will likely leave wood flakes in the concrete when you remove the forms.
    Remember, wet concrete weighs about 145# per cubic ft, or almost 2 tons for a cubic yard...so you need to brace brace brace!
  4. Marshel54
    Marshel54
    Looking at Lowes. 7/16 OSB Sheathing $7.25 23/32 OSB sheathing $15.18 1/2" sheathing plywood $30.57. So there is a lot of savings to be ate up with bracing. Don't really care about wood chips, just trying to preserve. Was more worried about it getting mushy from the water in the concrete.
    Getting older and are entertaining some thought of moving to reduce maintenance on the place.
  5. chris
    chris
    SE WI
    There is a release agent that you apply to the sheathing material - keeps that darn flaking and de-lamination at bay .
  6. Canadian border VT
    I've done it with three quarter inch marine. do yourself a favor get a drill bit and drill the holes I didn't get the concrete ties that you can attach to the holes to hold it in place. Basically it's called building your own forms. And then brace it..
    2 feet high not problem what's length and any corners.
    FYI about 40 feet plus and you need a buttress or support wall..
  7. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    I used to do walls and flat work. Depending on weather you’re just “patching”, or repacking entire sections will determine the pressure placed on the forms. As said above, using wire ties and 2x4’s with cam locks will make it. Ugh easier.
    So if it were me, I’d do some looking and asking about older contractors that may have some forms laying around you could maybe rent? I know the guy I used to work for hasn’t used his form-ply forms for over 10years and they just sit.
    3/4” plywood or OSB could work with the right bracing. Ties, Rods, 2x4’s, and cam locks make it a solid structure that won’t budge when filled with concrete.
  8. ironpony
    ironpony
    Mid Ohio
    7/16's will be fine, build a 2x4 "wall" 16" on center and "sheathe" it with the OSB, a baby wall. The most important point is the ground contact, head pressure will want to push the bottom of the forms out, 2 foot up will have minimal preussure. A few 2x4 braces, every 4 feet, and you are good to go. Use diesel fuel as a release agent or form release your choice.
    Build several sections, pour, remove and relocate forms and pour some more.
  9. brenndatomu
    Good point...wet concrete acts like a liquid, pressure is highest at the bottom of the "tank".
    Just curios, how thick will this concrete be?
    T.Jeff Veal, Screwloose, Chaz and 3 others like this.
  10. Eric VW
    Diesel makes a fine release agent.
  11. Canadian border VT
    Length is still important!!!
  12. brenndatomu
    So what you are trying to say is size matters?! :whistle:
    T.Jeff Veal, Chaz, Chvymn99 and 3 others like this.
  13. Canadian border VT
    Yes:rofl: :lol:
    Over 40 feet needs buttress IME
  14. Screwloose
    Screwloose
    In my experience form thickness is not as important as the bracing. Even 3/4" plywood is still plenty flexible to cause problems. Consider calling rental places, they have them for rent by me. A failed pour will cause much more of a loss that overcautious bracing.
  15. Marshel54
    Marshel54
    actually went down and laid the tape measure to it. 8" thick x 16" x 14ft long. That is what I am looking at for now. Next pour will be the same except 45' long.
    I hadn't gave rental a thought. Will have to check them out.
  16. ironpony
    ironpony
    Mid Ohio
    7/16's will be fine, build a 2x4 "wall" 16" on center and "sheathe" it with the OSB, a baby wall. The most important point is the ground contact, head pressure will want to push the bottom of the forms out, drill the bottom plate and stake it in place with rebar or concrete pins, 16"s up will have minimal pressure. 2x4 braces, every 4 feet, and you are good to go I would also run 2 pieces of rebar inside the concrete wall so when it cracks does not separate.
    there are 2 types types of concrete
    cracked
    and gonna crack.
  17. blacksmith
    blacksmith
    central Pa
    As Eric VW said make sure that you use a release agent, otherwise you'll be pulling your plywood apart when you're taking the forms down.
    I've never heard of using diesel fuel I am sure that would work fine. When I was working construction they would always use linseed oil it's a little thicker.
  18. Eric VW
    Maybe just a SW Virginia thing....?
    Been a while since I did any concrete work tho.
  19. brenndatomu
    Nah...its common here too...I've even seen large contractors use it.
    Asphalt trucks spray it in their beds before a load too...plus all the tools/equipment get cleaned up with diesel fuel...usually offroad diesel
    blacksmith, Chaz, Screwloose and 2 others like this.
  20. ironpony
    ironpony
    Mid Ohio
    and it drives the greenies nuts....................:loco: :crazy:
