Made a huge difference.
Discussion in 'Chainsaws and Power Equipment' started by trail twister, Apr 1, 2018.
  1. trail twister
    trail twister
    Before I put a couple hours work in.
    After a hours work and confirming there is beet juice AKA Rim Guard in the tires.
    Need wider mud guards now. Not much tire under the fenders. I did a search and I have not found where any one makes any. Some conveyer belting will work.
    :D Al
    M2theB, blacksmith, HoneyFuzz and 6 others like this.
  2. Flamestead
    Flamestead
    Windsor County, VT
    Weight down low and wide sure is nice - Now add some ice pick chains and you’ll be unstoppable! I often throw an implement on the rear when doing heavy loader work, but refuse to buy a box of rocks to make up for these modern lightweight tractors. Looks like you’ll just need to stay on the snow or keep it under 2mph to keep from throwing mud! (I’m in mud now, and it squirts and splashes all over)
    blacksmith, HoneyFuzz, Hammy and 2 others like this.
  3. trail twister
    trail twister
    I have 6 suit case weights I hang on the back blade if doing some heavy lifting with the loader. They weigh 65 pounds each,about 390 pounds plus the back blade.
    :D Al
    blacksmith, HoneyFuzz, Hammy and 3 others like this.
  4. Hammy
    Hammy
    New Brunswick
    HoneyFuzz likes this.
  5. trail twister
    trail twister
    Thanks.
    :D Al
    Hammy likes this.
  6. trail twister
    trail twister
    We have been in mud way to long about 2 months. About the time it is starting to dry we get more snow like this morning after last nights rain. so we can count on more days in the mud.
    :D Al
    Hammy and HoneyFuzz like this.
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Looks just right !!
    Hammy and savemoney like this.
  8. LodgedTree
    LodgedTree
    Maine
    I would not like the toolbox location, especially being plastic where being backed into something it might break, but I noticed a lack of spots. Mine is on the right rear fender, but I see a cup holder is on there now, so there is no where else to put it.
    Myself, digging gravel in my pit requires the most counterweight, so I put on my land plow, then set a 55 gallon drum on top of that filled with rocks. That gives me a lot of weight, but also allows me to bust up my gravel that I am digging...a two-fer if you will.
    Hammy likes this.
  9. trail twister
    trail twister
    If you back up and hit some thing to break the tool box your going to be breaking and bendind more than that cheap old tool box.
    The quick hitch protects it too.
    :D Al
  10. LodgedTree
    LodgedTree
    Maine
    Oh I know, you ought to see the back of my tractor after 19 years of use in the woods!!
    Hammy likes this.
  11. trail twister
    trail twister
    I am more careful of my equipment.
    :D Al
    Hammy, Stephiedoll and 94BULLITT like this.
  12. Flamestead
    Flamestead
    Windsor County, VT
    I’m pretty careful, but I’ve broken those silly exposed fender-mounted flashers twice now. On the M series you have to unbolt the fender to get in underneath to get at the light bracket. I’m hoping I have learned my lesson this second time.
  13. LodgedTree
    LodgedTree
    Maine
    Yeah me too. Most of the time it is the chains hooking into a stick and bringing it up and around and smashing them, so it is hard to guard against that.
    Flamestead and Hammy like this.
