  1. The Annual Tradition is Back!!!! It's time for our Annual Firewood Hoarders Club Secret Santa Gift Exchange! Deadline is: Sign Up will be closed on Saturday November 9th at Midnight (central time) Official FHC 2024 Secret Santa Gift Exchange
Love Joy coupling on Huskee log splitter
Discussion in 'Chainsaws and Power Equipment' started by TurboDiesel, Mar 11, 2019.
  1. TurboDiesel
    I had to replace the Love Joy coupler between the hydraulic pump and engine on the Huskee/Speeco log splitter. The coupler was worn to the point of failure.
    The engine is the Briggs and Stratton 6.75 HP with a 7/8" shaft. The pump is a Speeco with a 1/2'' shaft.
    There are 3 parts total.
    (2) coupler halves and (1) synthetic rubber insert.
    The coupler was a 3/4" coupler. I'm not sure if Tractor Supply had the 3/4" couplers in stock but Ryan suggested I upgrade to the 1" coupler as it is heavier duty. It was a pretty straight forward replacement. Needed to remove the four bolts (with a 1/2" wrench and socket) that held the pump in place, and one set screw on each coupling half (using an 1/8" allen wrench). The coupling half on the pump shaft was a little tight and the shaft seemed to move in and out of the pump pretty easy so I used a puller to get it off rather than prying it and risking damaging the pump.
    pictures to follow.
  2. Horkn
    Sometimes they go off easy, sometimes they are stuck.
  3. Eric VW
    Gooder on you Tim for not laying them PA manacle hands on the fix in a harsh way....:whistle:
    :thumbs:
    :salute:
    :D
  4. Backwoods Savage
    Ya, the danged things do tend to break at times. Can be nasty to fix if they don't come apart good.
  5. mikeward
    mikeward
    Long Island, New York
    2 years ago my splitter had the same problem
    searched here and there were no posts on repair
    here is the thread
    Love joy sheared on splitter
    both halves were on really tight
    engine one came off fine with puller
    pump half barely had room for puller- I had to grind it down a little
    Best tip from someone was to use grinder to cut into bad Lovejoy to better attach puller instead of modifying puller
  6. amateur cutter
    I put the metal halves back on with anti seize. Use a hose clamp to get the alignment exact, they last longer that way.
  7. bigfrank
    bigfrank
    NorCal
    Okay, I give up. What is a Love Joy coupler???
  8. MAF143
    MAF143
    North Central OH
    Well, sometimes it starts over dinner at a fine resteraunt, sometimes after a movie, or even in a bar after too many drinks... OH wait, that's a love, joy coupling, my bad (other forum)!
    You mean the coupling to transfer rotational power from an output shaft to an input shaft to isolate vibration and ensure alignment issues don't cause premature failures.
  9. TurboDiesel
    a coupler (on the log splitter) between the engine and hydraulic pump.
    Love Joy is a brand name:yes:
    Welcome to the club, bigfrank !:handshake:
  10. MAF143
    MAF143
    North Central OH
    Sorry to be such a wise aker, welcome aboard!!!!
    OK, I'm not really that sorry...
  11. dall
    dall
    West Virginia
    you can save some money by changing the rubber piece before the metal cogs start touching each other as well i do that on my little tractor because i welded the coupler piece on the front pto shaft
    metalcuttr, campinspecter and Chaz like this.
  12. bigfrank
    bigfrank
    NorCal
    Ahhh, thanks MAF
  13. Screwloose
    Screwloose
    If you upgrade to a hytrel spider you will probably get longer life.
  14. EMS779
    EMS779
    West Virginia
    About this Love Joy Coupler. I have a 20 ton Tractor Supply splitter, I bought it used, and I have had to replace the Love Joy coupler twice already and it just broke again. Obviously something else is wrong with the splitter. Anyone have any ideas?
  15. Horkn
    It's probably an alignment issue, these are typically pretty forgiving though.
    Any pictures?
    metalcuttr and campinspecter like this.
  16. dall
    dall
    West Virginia
    alignment issues
    pictures of the set up
    could be loose bolts
  17. Horkn
    Great minds....:thumbs:
  18. TurboDiesel
    My engine bolts came loose one time.
    I'd guess that made mine wear prematurely. It made a lot of noise like it was missing or running rough
