Loosening screws
Discussion in 'Chainsaws and Power Equipment' started by dgeesaman, Jan 19, 2015.
  1. dgeesaman
    dgeesaman
    Elizabethtown, PA
    After rebuilding my 365 into a 372XP, I got maybe 10 minutes of operation before a couple of screws came loose.
    I'm inclined to reassemble with Loc-tite 248 (blue paste) since the threads are small but I'd like to hear your individual recommendations.
    David
    wildwest and HoneyFuzz like this.
  2. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I use blue locktite ... Seems to work just fine !
    Horkn likes this.
  3. Mag Craft
    Mag Craft
    South East Wyoming
    I use blue loctite all the time.
    HoneyFuzz likes this.
  4. Horkn
    Yes, blue loctite is anything with a motor's friend. Even small screws. Just don't use red on the small screws, unless you're a sadist and like drilling and retapping and swearing a lot.:headbang:
    HDRock and HoneyFuzz like this.
  5. raybonz
    raybonz Moderator
    Carver, Mass.
    Pink Loctite recommended on small screws.. Red forget about it! Blue OK on larger bolts..
    MasterMech and HoneyFuzz like this.
  6. pappy88
    pappy88
    Missouri
    I always use rtv silicone, never a problem.
  7. clemsonfor
    I like the silicone idea.
    As for loosening screws its a husky. Hideing under the table now. I have a husky and it chronically looses bolts. The recoil assembly seem to be the worst offenders.
    concretegrazer likes this.
  8. Horkn
    I forgot about the pink stuff. On the small screws I only use a tiny amount of blue applied with a toothpick to a small area, and I don't coat the entire way around the screw. That method works the same as the pink stuff that not many people have. But if you have pink, use it.
    HoneyFuzz and raybonz like this.
  9. clemsonfor
    Never heard of pink. But I am not a guru in the various goops and such you get for various tasks.
    Thats good to know though.
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    Horkn and HoneyFuzz like this.
  11. Horkn
    Pink/ purple, nearly nobody knows about it or uses it. I learned the trick with using a tiny amount of hours through work, but I've also seen "blue threadlocker" on tiny motorsport screws on carbs linkages sensors etc , that had full thread coverage of locker, but those screws are usually torx or better head types than phillips.
    I've heard about folks using silicone sealant on items like this, I've just never used it for that use.
  12. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Ive never heard of the silicone idea ! Does it work good ? How bout when its time to unscrew ?
  13. foragefarmer
    foragefarmer
    Central, Virginia
    I have used the blue rtv on bolts and not just on chainsaws. It works fine and breaks loose fine but it can be a little gloopy on the threads and takes a little bit to clean them off to reapply. Good in a pinch. Usually use blue locktite.
  14. Hedgerow
    Hedgerow
    SW Missouri
    I use red loctite in stick form on all my Huskys... It's a steel to magnesium thing... I've not had a problem getting them back out..
    Yet...
    HoneyFuzz, raybonz and dgeesaman like this.
  15. dgeesaman
    dgeesaman
    Elizabethtown, PA
    I just went over the saw using a bit of the Loctite blue 248 goo stick. Hopefully tomorrow i can get back to cutting.
    Moparmyway and HoneyFuzz like this.
  16. nmurph
    nmurph
    You don't have your screws tight enough if they are backing out. Look at the screw when it comes out. If it had some sort of retaining compound on it, then you probably need to re-install it the same way. But save the cylinder bolts, very few saws will have anything on any of the bolts.
    Sunfish, concretegrazer and HoneyFuzz like this.
  17. mike bayerl
    mike bayerl
    Replace all screws with T-27 torx (like a proper Stihl). Thereafter, if you need it, Blue Loctite works great.
    clemsonfor and HoneyFuzz like this.
  18. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Huskys dont like being screwed by a Stihl :)
    cnice_37, Ralphie Boy, HDRock and 3 others like this.
  19. nmurph
    nmurph
    You are mixing a Torx head which simply means the type of tool needed to fasten/loosen with the fact that Stihl fasteners are serrated on the underside.
    clemsonfor likes this.
  20. mike bayerl
    mike bayerl
    :cool:
    Glad to see a sense of humor around here.:thumbs:
