Look at this splitter
Discussion in 'Chainsaws and Power Equipment' started by Kevin in Ohio, Dec 19, 2018.
  1. Kevin in Ohio
    Kevin in Ohio
    See what you guys think:
    I made a comment about the tonnage claim but why on earth do these companies mount the valve like that? Not normally a safety nazi but that looks like a REAL bad idea. I guess they don't think things vibrate and get flexed from back and forth pulling. They need to go back to engineering school in my opinion.
    It's a 6 inch bore with a 22GPM pump so they have to be pumping 4250 PSI to get that. Don't think that valve is rated for that.
  2. Screwloose
    Screwloose
    One slip with a log and the only thing holding the valve will be hoses. Hard to say what the valve is capable of but I'm going to say it's a stretch. It would be cheaper to up the cylinder size rather than the added cost of higher pressure rated components. Probably the same engineer who came up with older Sears horsepower ratings. Remember the 5 hp 110volt air compressors.
    Brandon Scott, mat60, HDRock and 6 others like this.
  3. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Is it just me, or is the cycle time pretty slow?
    mat60, Maina, OhioStihl and 8 others like this.
  4. Kevin in Ohio
    Kevin in Ohio
    That's the drawback of a 6 inch bore. They advertise a 22GPM pump so that is what you get. I was going to use a 6 inch cylinder on mine but when I figured the cycle time and decided against it and I'm using a 28 GPM pump. The other issue is heat and restrictions. All those hard 90's and small fluid tank is another minus. If they have used a double wall pipe for strength on the valve mount nipple that ID would be extremely small. It would be interesting to see the temps this splitter develops after a 1/2 hour of constant use.
  5. jrider
    jrider
    Pretty slow? It's a damm snail!
    Also, can't stand how he splits the pieces that need to be resplit. Notice the first one, he lays it down so you get 2 large pieces on the bottom and 2 tiny pieces on top. If he took the log and stood it up, he could get 4 equal size pieces.
    One more thing, I can't stand running a splitter where the ram is the wedge. Way more work in my opinion on pieces that are stubborn and need that final inch or two of push.
  6. NYCountry
    NYCountry
    Mohegan Lake NY
    The best splitter I have seen so far is the power split, it's expensive but that thing is a beast and it comes with a log lifter
  7. Kevin in Ohio
    Kevin in Ohio
    That is a trade off. If you have a conveyor out the back then your point has more validity. I made the wedge on the ram on my because when doing the big stuff you have to pull all those big pieces back for resplits, get one side out of the way or let it hit the ground if no table is there. They advantage with my set up is I also have a 3rd "storage with it hanging and can swing out of the way. If I'd have it opposite it would swing back on me as it pushes the round away.
  8. Rowerwet
    Rowerwet
    Seacoast NH/MA
    That cycle time is enough to put me to sleep watching it.
    I get the four way wedge, but really would want to be able to remove it quickly for resplits.
    Got to love the inexperienced operator carefully setting the rounds against the foot, the ram will do that for you just fine.
    The valve in the middle is nice for left handed operators, especially when run vertically. I don't get the tall stand pipe it's mounted on though.
    Fixed wedges are more work for the big stuff, forcing you to wrestle the resplits back around the wedge for another pass.
    They make for a longer machine to have a table to catch the splits past the wedge.
    mat60, amateur cutter, Hammy and 5 others like this.
  9. TurboDiesel
    the wedge on the ram is the only way you can use it vertical.
    mat60, Maina, Horkn and 9 others like this.
  10. WeldrDave
    Many splitter companies do that. I saw an Ariens that broke off in our shop at the base that belonged to someone. I believe a log flew back and busted it off.
    mat60, Maina, amateur cutter and 7 others like this.
  11. WeldrDave
    I know everyone is saying how slow it is, "But" it still beats, Beating the hell out of the wood with a sledge and a wedge! :headbang::p
    mat60, Maina, Horkn and 11 others like this.
  12. Rowerwet
    Rowerwet
    Seacoast NH/MA
    Having never seen wood fly anyway but sideways, I'm having a hard time imagining that
  13. WeldrDave
    I'm "assuming" it was caught on the wedge, came back and hit the stop bars. I didn't see it happen, "what I was told". Thats why I said I believe, Either way it was broke. o_O
  14. Backwoods Savage
    And don't you just love all the advertisements for splitters show them splitting some very easy splitting wood! I remember the last time TSC had a demo on their splitters. I was there as a pickup came loaded with wood for them to demo splitting. It was dead wood for sure. Some would almost fall apart just looking at it.
    Why don't they ever show splitting some decent wood that really requires a log splitter?
    mat60, Maina, Rowerwet and 7 others like this.
  15. jrider
    jrider
    I will agree on you with the big logs that can be an advantage but who splits nothing but big pieces? Also, once you break them down into manageable pieces, they aren't big anymore.
  16. jrider
    jrider
    Oh I know. I have done plenty of shopping around for splitters through the years and that's why I never bought one that goes vertical.
  17. jrider
    jrider
    Agreed for almost all of them. Check out Eastonmade splitters though for a real life test. Those are some nice machines!
  18. Backwoods Savage
    Now that is a first!
    mat60, amateur cutter, Chaz and 3 others like this.
  19. Kevin in Ohio
    Kevin in Ohio
    I guess me. ;) I normally get calls from people who can't handle them and I bust stuff up to a size I can carry. everyone has there own way of doing things so it's all good. We split where it lays by backing down the log length. If we throw to both sides, we back the truck down the same path and load from both sides with basically no steps. If a conveyor or straight to a truck, it's off to the side if room allows.
  20. WeldrDave
    Sweet gum is "NO JOKE"!!! I think it's worse than elm! I have lots of it here... That's a Bad @$$ machine to rip that stuff apart!
    Felter, mat60, AlfA01 and 9 others like this.
