Long distance insecticide sprayer?
Discussion in 'Chainsaws and Power Equipment' started by cezar, May 6, 2025.
  1. cezar
    cezar
    KY
    Tried searching this but the only thing that comes out of search engines anymore is AI slop.
    I need a garden / insecticide sprayer that can reach 3 stories up so I can hit the soffit areas on my roof. I've got a log home and I need to control carpenter bees. Does anyone know of a sprayer that can hit that sort of height?
    John D, Screwloose and brenndatomu like this.
  2. RCBS
    RCBS
    Over here
  3. cezar
    cezar
    KY
    I do have a pressure washer but it seems like that might end up in a somewhat toxic mess all over the place.
    Might work tho...
  4. Screwloose
    Screwloose
    How about a backpack aka mosquito blower sprayer? Something pet safe like bifenthrin works well. The houses i spray get the soffit area sprayed no issues.
    brenndatomu and John D like this.
  5. Rothk
    Rothk
    WVA
    Someone might make a drone you could attach a RAID can to...
  6. cezar
    cezar
    KY
    My main issue with a backpack sprayer is I have other things to spray like herbacide and if I'm spending 200+ on a sprayer I need it to be able to handle multiple chemicals without an in-depth cleaning.
    Now if there was a backpack sprayer that had interchangeable tanks that would work.
    EDIT: looks like Milwaukee has a interchangeable tank sprayer but it comes with 2 problems:
    - Too expensive ($400)
    - Only shoots 25' which I don't think is enough to cover 3 stories
  7. Screwloose
    Screwloose
    I have used a cheap compressed air hand pump sprayer by adding a hose between the nozzle and trigger and zip ties and tape to hold it to a few lengths of emt conduit.
  8. brenndatomu
    Seems like it would be easy enough to make one from a portable air tank and a trip through the crop sprayer isle at the local farm store...might have to use a small 0* pressure washer tip for the nozzle?
    Screwloose and eatonpcat like this.
  9. lukem
    The wands on the 12V spot sprayers from TSC will reach out a pretty good distance. Worst case scenario you might have to do it from a ladder.
    brenndatomu and eatonpcat like this.
