Log splitter.
Discussion in 'Chainsaws and Power Equipment' started by tg.weaver, Nov 4, 2017.
  1. tg.weaver
    tg.weaver
    So the splitter went down replaced it with a new carb...80 bucks....went out to start it today to use it. It started the died. Now wont turn over at all. Not sure if i smoked the starter. Didnt bliw the fuse. Dont know what else could have gone wrong. Any ides would be great. Thanks
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    TurboDiesel likes this.
  2. TurboDiesel
    Check battery?
    Pull the spark plug out and see if it turns over easy.
    Check the obvious first. Oil level ok? Many small engines have a low oil cut off. If its sitting out of level it will do the same thing.
  3. TurboDiesel
    What brand of splitter is it? Motor?
    Horkn and Backwoods Savage like this.
  4. tg.weaver
    tg.weaver
    Well its a huskee splitter, with a techumins engine.
  5. tg.weaver
    tg.weaver
    Oil is good, its level.
  6. TurboDiesel
    check the ground, may need to connect the ground to the frame.
  7. tg.weaver
    tg.weaver
    Yup it is i kinda wonder if maybe the solenoid might have been burnt up.
  8. Backwoods Savage
    Does this also have a recoil starter?
  9. tg.weaver
    tg.weaver
    No it does not
  10. Backwoods Savage
    That is sad as sometimes you can tell much just with the recoil starter. Have you tried jumping it?
    Horkn likes this.
  11. tg.weaver
    tg.weaver
    Well i was using a jump box. I havent tried to use a car or gator battery.
  12. 94BULLITT
    94BULLITT
    Frederick County, VA
    Try turning it over by hand or with a socket and ratchet on the crank bolt. You will have to take the blower housing off. The starter is not jammed in the flyhweel is it? Did it make any funny sounds?
  13. tg.weaver
    tg.weaver
    No nothing no noises at all. Ill try that tomorrow though.
  14. tg.weaver
    tg.weaver
    Ok just came back in from checking stuff. Something has to be wrong with innthe starter before the motor. Grounded the jump box on the block and touched thw positice to thw positive on the starter. It turned over but was really hard to turn over. Tons of sparks. But it would not spin enough to start. Is it possible i tightened down the housing the covers the timing too tight? Or is this a more major issue? Granted the engine has issues.
  15. tg.weaver
    tg.weaver
    This is what the exhuast looks like the last time it ran. After about just 10 minutes. [​IMG]
  16. 94BULLITT
    94BULLITT
    When was the last time the valves were adjusted?
    Horkn likes this.
  17. 94BULLITT
    94BULLITT
    Is the muffler plugged up?
    Horkn likes this.
  18. tg.weaver
    tg.weaver
    Last week. It ran afterword while we adjusted the carb. Shut it down and i pulled it out just the other day to split some wood
  19. tg.weaver
    tg.weaver
    No nothing in it. Pulled it off and check to the block and through the muffler.
  20. 94BULLITT
    94BULLITT
    Was the exhaust glowing b4 the new carb?
    Horkn likes this.
