Lock N Stitch cast iron repair????
Discussion in 'Everything Else (off topic)' started by Unicorn1, Mar 8, 2019.
  1. Unicorn1
    Unicorn1
    Amarillo, TX
    Has anyone used this method before? I'm working on a bandsaw. 20190308_101846.jpg 20190308_101900.jpg 20190308_101853.jpg
  2. ironpony
    ironpony
    Mid Ohio
    done properly it is very strong, labor intensive to do, the pins are fairly expensive. The sell kits, drill bit tap and pins.
    looking at those cracks not sure it will work they look like it broke into 2 pieces???
  3. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Brazing is cheaper and faster.
  4. ironpony
    ironpony
    Mid Ohio
    Do you have any local foundries?? I restored a tractor one time and was able to convince the owner to cast me some pieces. I think he found it interesting and something different to do. I made the patterns and he ran them thru for $5 each at the time, I needed 40 pieces. I know he thought he would never see me again being he told me to bring him useable patterns. Little did he know I was a tool maker and had made many patterns. I actually made the patterns so he could cast 4 at a time saving him time.
    That part is fairly simple, you could probably use it as the pattern for the casting. You would have to drill and tap all the holes after casting.
    Backwoods Savage and Screwloose like this.
  5. Screwloose
    Screwloose
    Lock stitching only works on captive cracks, like a water jacket on a engine. It's a plug basically with no actual joining capability. Try stick welding with nickel rod first and if a no go brazing will probably take. Either way probably better to fish plate it afterwards.
    brenndatomu and Backwoods Savage like this.
  6. Backwoods Savage
    The only fixing I've ever done on cast is JB Weld. It is amazing how many things can be fixed with that junk.
    Screwloose likes this.
  7. billb3
    looks like a praying mantis egg mass and some other (caterpillar ?) egg mass in pic 2
  8. Screwloose
    Screwloose
    I suppose I should have said it before but that frame would be very easy to fabricate completely from steel. Very few of the dimensions are important and it all could come out of flat plate with no bending.
  9. Unicorn1
    Unicorn1
    Amarillo, TX
    I'll have to inspect the cracks closer to see if they go all the way through and are held together by the plates.
  10. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Brazing is almost as strong as the cast. Those little carbide teeth on a saw blade are brazed on as carbide cannot be welded and they take alot of abuse. If you decide to weld it grind a U shaped grove (not a vee) pre heat to 500°F weld it with the high nickle rods, then peen, then cover it with sand so it cools VERY slow or you will hear a really cool snapping sound. Now all of that said are you sure that it is cast iron or is it cast steel? Do a spark test with a grinder to find out. If it is cast steel weld it as you would any piece of A36.
  11. Unicorn1
    Unicorn1
    Amarillo, TX
    I'll check it out Sunday, thanks everyone. :)
    Fifelaker and Screwloose like this.
