Lighters
Discussion in 'The Wood Pile' started by scootsaw, Oct 17, 2023.
  1. scootsaw
    scootsaw
    What do you all use to light your fires? I use the plastic "multi-purpose" lighters but they feel so cheap. I want to use something that is quality and gives more satisfaction when lighting, if you know what I mean.
  2. buZZsaw BRAD
    I use matches. Free at most gas stations. When GF smoked id use her lighter. The cheap wand type lighters seem ideal for such. Ive seen small hand held propane torches used as well.
  3. Warner
    Warner
  4. RGrant
    RGrant
    Connecticut
    Primarily I just use the box of stick matches. I do have a couple of the plastic wand lighters with the trigger but those are usually down in the basement with the camping gear. The matches stay up in the liquor cabinet away from the kids.
  5. Sawdust Man
    Sawdust Man
  6. The Wood Wolverine
    edit:
    I use wooden matches.
  7. Ohio
    Not Ohio
    A big box of matches is 3 dollars so thats what I use.
  8. coreboy83
    coreboy83
    NW of Twin-Cities
    Box matches. Re-kindle 9/10 times though. I'll use a match when I scoop out, because I let it die down over night.
  9. woody5506
    woody5506
    Upstate NY
    Bernzomatic. I got so sick of stick lighters crapping out after what seemed like a month or two that I finally just bought a torch specifically for the stove. A tank of map gas if just using it for lighting the stove or other stuff like charcoal, bonfires whatever will last a long time. It ends up being cheaper than stick lighters in the long run.
  10. Biddleman
    Biddleman
    River Hills of Pennsylvania
  11. billb3
    plain ol' book matches
  12. JiminyKicket
    JiminyKicket
    Seattle
    Wood matches because they come with their own tiny piece of kindling
  13. Eric Wanderweg
    Last year I replaced the tank on mine, which I bought in 2011 :thumbs:
  14. Highbeam
    Highbeam
    Me too. I actually own one for each stove and they are very quick and satisfying to use. They also can be very good for preheating the flue if that's needed by shooting torch heat up the stack. I refill the green propane cylinders from the BBQ size tanks that I pay 2.19$ per gallon to fill. So we're talking 10 cents of propane used per year by the torches. The trigger ignition parts have lasted 100% over the many years I've used them, not sure if they ever wear out.
    Then of course having a finger trigger operated torch is handy for all sorts of things. Have something cold that you need hot, grab the torch. A little creme brulee? Need to melt some wax? Thaw the chicken waterer? A frayed rope?
  15. thescratchylens
    thescratchylens
    Rock County, Wisconsin
    Unstick the frozen lock on your shed or trailer? Check. I love my Bernzo. It’s what I’ll use once our insert is installed.
  16. brenndatomu
    Or sometimes free after rebate at Menards...but haven't seen them that cheap since CV19.
    I generally use the wooden matches, or sometimes a Bernzomatic torch...
  17. RCBS
    RCBS
    Over here
  18. RCBS
    RCBS
    Over here
    Who can name that movie? ^^
    Cheap Bic lighters start my fires.
  19. theburtman
    theburtman
    I use the stick lighters
  20. Ronaldo
    Ronaldo
    Zippo lighters are quality and have a quality feel.
    Sent from my SM-S536DL using Tapatalk
