Lets talk about Stihl Rim Sprockets
Discussion in 'Chainsaws and Power Equipment' started by 94BULLITT, Aug 21, 2015.
  1. 94BULLITT
    94BULLITT
    Frederick County, VA
    On modern Stihl saws are there just 2 types of rim sprockets, small and mini? Is it true that the Oregon replacement rims for small will not fit a Stihl clutch drum?
    clemsonfor likes this.
  2. Cut4fun
    Cut4fun
    OHIO Redneck
  3. 94BULLITT
    94BULLITT
  4. SquareFile
    SquareFile
    somewhere
    Your 441 & 660 use standard. The smaller saws you listed use mini hub. I'm not certain about the 034. It may be small hub or mini hub.
    mdavlee, Cut4fun and 94BULLITT like this.
  5. Cut4fun
    Cut4fun
    OHIO Redneck
    Thanks SF.
    Standard oregon fits standard stihl also. So not to confuse people by OP post in beginning.
  6. 94BULLITT
    94BULLITT
    The 034 use the same rim as the 024, 026, and 261. So some mediuim size saws use small?
  7. SquareFile
    SquareFile
    somewhere
    Your 034 would be mini then.
    Smaller saws other than Stihl use small hub more often.
    94BULLITT likes this.
  8. concretegrazer
    concretegrazer
    Southwest MO
    So which hub is a 346?
  9. SquareFile
    SquareFile
    somewhere
    Small
    concretegrazer likes this.
  10. SquareFile
    SquareFile
    somewhere
    Here's the measurements or descriptions for each.
    Standard 7/8"
    Small 3/4"
    Mini 11/16"
    94BULLITT, mdavlee and concretegrazer like this.
  11. MasterMech
    034s were mini hubs from the factory. It was very common to upgrade them to the same hub as the 036/044 so both sizes are out there.
    94BULLITT and mdavlee like this.
  12. 94BULLITT
    94BULLITT
    I think I got it now. Stihls 50cc and under with the exepction of some or all 034s are mini. 60cc and larger Stihls are standard. Small spline is aftermarket for Stihls that use mini spline but a small spline rim will not fit a mini spline drum.
    I like that the 034 has a mini spline drum because I can run picco on it if I want and have the correct rim on it.
    MasterMech and clemsonfor like this.
