Lean to Firewood storage
Discussion in 'The DIY Room' started by Unclefish, May 25, 2020.
  1. Unclefish
    Unclefish
    Northeast
    I had 1 nice rack along the wall to right. The rest was on pallets with just tarps over them that always get shredded up in the wind. I want to build 2 lean to sheds that lean foward on each side of the center door. It was grass and mud always so I put down 4 inch's of processes and I had a bunch of used pavers so I will have a walk to run the wheel barrow in to the cellar. The sheds will be wide enough to fit 2 rows of wood with open front. My question is should I leave the back with some 4 inch gaps so wind will continue to dry and floor will be decking should I leave 1\4 to 1\2 inch of room between decking boards also. The back will be about 4 inches out from wall of house.
  2. Horkn
    It's leave 1/4" between the decking boards to help with air flow.
    So are you going to have some sort of window protection?
    Got a napkin or paint sketch to help us visualize?
    Chazsbetterhalf likes this.
  3. Unclefish
    Unclefish
    Northeast
    Left of center cellar door will be the full 11 ft by 4' 6" Right of cellar I have to leave room to get in that's the single row for 7'6" so I can get into that side door where my wood stove is. Here's a quick scetch
  4. Unclefish
    Unclefish
    Northeast
    And the back boards is what I was talking about leaving 4" between those will be 1 x 6 verticals so it will protect wood from falling into window.
    Been lucky for 15 years I usually stack the wood up to about the second row of siding . Stood on latter stacking all the way across. 1 night it did fall over away from the house left of the center door. What a noise that was.
    Chazsbetterhalf and brenndatomu like this.
  5. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I’d leave a 1” gap in the flooring, more air and less flooring to buy. I would leave an air gap in the back also. I like air. I’d have the floor about a foot off the ground, keeps from getting moisture from the ground. When I built my woodshed I left a 1” gap at the to and bottom of the siding so that would circulate air as well.
  6. Unclefish
    Unclefish
    Northeast
    Couple night this past week and this weekend coming along .
  7. Unclefish
    Unclefish
    Northeast
    Why do projects always take way longer than expected
