Last load for a while, pics
Discussion in 'The Wood Pile' started by bogydave, Oct 18, 2014.
  1. bogydave
    Sun getting later & later, but nice it was out this morning.
    Ruts on the trail,
    Ground like concrete this AM, 29°
    Snow level moved up a bit more, was 44° & windy when I left around 6 PM
    Wood & atv trailer loaded,
    loading the atv up.
    Another offload
    Stack of birch rounds is getting bigger.
    Back before dark , today
    Body needs to recover a bit.
    Reminds me, better take a few iboo
    Gark, Mitch Newton, Stinny and 11 others like this.
  2. bogydave
    Can just see the mts thru the trees now, I've cut enough trees to have a view :)
    milleo, Gark, Lumber-Jack and 9 others like this.
  3. NYCountry
    NYCountry
    Mohegan Lake NY
    Nice rounds you got there. What year will this load be for ? Nice work and set up
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    Nice work Dave! Is this about the time of year in most years you call it quits?
  5. HDRock
    You got a heck of a good start on it there Dave :tree:
    Nice neat stack of rounds :thumbs:
    Shawn Curry likes this.
  6. schlot
    schlot
    NW Iowa
    I like that trailer/atv/trailer system you have. Is that something you came up with?
  7. Locust Post
    Well you were a little unsure at the start, new area and all but you're getting there. Pile is getting bigger.
  8. Well Seasoned
    You have the bestest setup Dave to get the job done! Always love your pics!
    HDRock, Chvymn99 and Shawn Curry like this.
  9. papadave
    I knew it wouldn't take long before you got the wood to refill the pallets.
    You now have a "cube o' wood".:thumbs:
    I hear ya' on the body needing a rest. :sleeping:
    Gark, HDRock, Chvymn99 and 1 other person like this.
  10. thewoodlands
    thewoodlands
    Nice work B.D., the ruts are pretty deep.
    papadave and Stinny like this.
  11. Gasifier
    Great work Bogy. Nice pics, thanks for sharing.
  12. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Always thought that trailer was ingenious!
    Nice stack of rounds too, birch sure is a nice looking wood
  13. bogydave
    Thanks
    17/18
    I tried to select good trees, I was being a wood snob
    But I got fooled a few times & got some that the base was punky in the center
    & one that had a rotten top section,
    All in all, mostly real good wood
    Gark, HDRock, NYCountry and 2 others like this.
  14. bogydave
    Thanks
    Yea,
    this time of the year I can get snowed out of the cutting area any time.
    The road/trail in has some steep part that I can't pull the loaded trailer up if iced or snow.
    (Barely make it now with a full load)
    Got stuck one time, was getting pulled back down the hill
    was in low , 4 wheel drive, scary, hard to keep the trailer straight.
    Took some work & a while to get out.
    So I quit when the trail becomes slick.
    Be nice to get a few more loads,
    never have enough wood. :)
  15. bogydave
    Thanks
    I got a used trailer , modified it a few years ago to fit my needs for the wood cutting area.
    Hard to find a place to turn around in there.
    I loose a couple tail lights every year.
    Had to un hook & fight it the first time in, learned turning around a 20" (from ball to rear)
    in the woods in=s not a good idea.
    ATV trailer is an addition this year , needed it because of warmer weather & mud.
    Working out better than skidding logs all the way to the truck/trailer. Bucking in the wood
    is much easier, faster & I don't have the dirt / mud /gravel in the logs to dull the chain.
  16. bogydave
    Loks like a 4 x truck guy was trying to get into the cutting area earlier & got stuck several times.
    Found some tail light & other truck parts on that section of the trail.
    Where the trail goes into the woods, it gets tougher, steep & narrower ,
    so he stopped & turned around there, but left behind a rutted mess.
    I bet it was a fight in & out .
    Thought about working on it, but then someone would try it again & make it even worse.
    :confused:
    papadave likes this.
  17. bogydave
    Thanks
    Birch is the best BTU wood here.
    Trailer helps me be a ltitle picky . (wood snobby) :)
    bigbarf48 and Chvymn99 like this.
  18. Lumber-Jack
    Lumber-Jack
    Looks good Dave, thanks for sharing.
  19. rottiman
    Really enjoy your pics Dave. 1st class system in an absolutely beautiful area.
    bigbarf48 likes this.
  20. bogydave
    Gr-daughter wanted to go see the wood pile
    Trying to be a sunny day :)
    milleo, Chvymn99, Lumber-Jack and 5 others like this.
