Kubota MX5100HST 4x4
Discussion in 'Chainsaws and Power Equipment' started by Chud, Apr 24, 2023.
  1. Chud
    Chud
    NC
    I will be looking at one later this week with 900+ hrs. Any known issues with the model? What should I inspect when I look at it? Is there major service due around 1000hrs?
  2. FarmerJ
    FarmerJ
    Minnesota
    Shake the bucket and look at the pivot bushings. Pretty much goes for all of the lube points, by the adapter pivots especially.
  3. Canadian border VT
    Kubota | Maintenance Schedules - Check Points
    a lot of things biggest I can think is is hydro fluid clear or milky. Is it quick attach or bucket??
    milky means wasn’t changed at 900 hours
    Use bucket lift front tire off ground in 4wd di the free spin or not.. free spin means 4wd not right
  4. Chud
    Chud
    NC
    Quick attach and 3rd function
  5. Eggshooterist
    Eggshooterist
    Erff
    Milky means water in the fluid no matter the duration.
  6. Screwloose
    Screwloose
    What was it used for by the previous owner?
    Turn the steering both ways till it stops and see if the steering wheel keeps turning.
    Is this a stick or hydro ?
    Look at the coolant in the radiator and see if any oil is present.
  7. Screwloose
    Screwloose
    And if so it's a pia to flush a tractor clean.
  8. Eggshooterist
    Eggshooterist
    Erff
    Yes. So many places for fluid to hide.
  9. Canadian border VT
    Your right, but I have seen People change it and not fix it..o_O
  10. Eggshooterist
    Eggshooterist
    Erff
    Yep. Me too. :(
  11. RCBS
    RCBS
    Over here
    I'm jelly! That's gonna be a nice ride.
    Being HST, the hydro oil and service should be considered critical. Fluid should be changed every 400hrs according to maintenance on my 03 HST. It's not hard to imagine someone not wanting to pay Kubota's price for UDT2 and throwing some $25/5-gallon stuff in there. Inner air filter should be a tell (unless they just did a quickie job for the sale). Is this at a Kubota dealer, or private sale?
  12. corncob
    corncob
    Somewhere in Lower Michigan
    Never, never use cheap fluid in any Kubota HST. Having owned at least 10 Kubota's over the last 25 years, I say that from experience. Having said that, neither of my present 2 are hydrostats. Both are hydraulic shuttle but then I farm with mine. Much prefer hydraulic shuttles for their simplicity and better power delivery not only to the wheels but to the PTO as well. Hydro's are inefficient for power transmission.
  13. corncob
    corncob
    Actually, milky fluid indicates the tractor was never worked hard enough to 'boil' off the condensation. All of them will make condensation in the gear cases, a product of cold castings and warm moist air.
  14. RCBS
    RCBS
    Over here
    Have not had any milky fluid in the 4 hydro changes I have done. Slightly darker but always clear. Same experience with other hydrostats I've changed (RTV900, ZD326, JD 2305)
  15. huskihl
    huskihl
    My old L 3600 had milky hydraulic oil. Short runs in cold weather and never allowed it to get heated up enough. The current L48 is Hydro and never has a problem with getting the fluid warmed up.
  16. brenndatomu
    That makes sense, the hydros do make some heat...unfortunately that's due to the hydro's inherent inefficiency.
  17. corncob
    corncob
    I never say that part but it's a fact. Just like a slush box in a vehicle, efficiency is lost with any fluid coupling.
  18. Eggshooterist
    Eggshooterist
    Erff
    And..... condensation is water. Like I said.
  19. Eggshooterist
    Eggshooterist
    Erff
    Same here.
  20. Eggshooterist
    Eggshooterist
    Erff
    The neighbors L2800 would get milky because he'd fire it up, use it a few minutes and put it away. I rarely do that. In cold weather I start mine, bring the throttle up to 1000-1200 rpm after the oil light goes out then go clean off the deck, steps and garage approach while it warms up. Usually 20-30 minutes then I plow.
