Kill switch not working
Discussion in 'Chainsaws and Power Equipment' started by Woodwhore, Jan 28, 2020.
  1. Woodwhore
    Woodwhore
    Mason NH
    Why do i have to choke my saw to shut it off? Thank you in advance
    Chaz and M2theB like this.
  2. MikeInMa
    The shut off switch on my huskys, is the choke. I push it down to shut off. No separate start/stop switch on them.
    My older husky40 does have a separate start/stop, but not the newer models.
  3. JB Sawman
    JB Sawman
    pennsylvania
    I do not know what saw you have but it could be as simple as a switch or the wire to the coil an or ground is broken on the stihls the switch contact is also suspect but in any case none of the problems are to difficult to fix
  4. Fifelaker
    Fifelaker
    Fife Lake Mi.
    What saw? It could be a number of things, broken wire, broken or dirty switch, if it is a Stihl the presences lever may be buggered up. The make and model would narrow down the possibilities.
    Chaz, M2theB and farmer steve like this.
  5. JB Sawman
    JB Sawman
    pennsylvania
    the newer huskys have a switch it is built into the same lever there is a contact when you push that lever down you lift the lever for choke
    Chaz, M2theB, Sandhillbilly and 2 others like this.
  6. Woodwhore
    Woodwhore
    Mason NH
    Husky 576xp is doing it and now the small echo 250 is doing it. Iv been running these saws hard for months now too.
  7. Woodwhore
    Woodwhore
    Mason NH
    Echo has a toggle switch on the opposite side of the saw
  8. Woodwhore
    Woodwhore
    Mason NH
    Im sure its simple, id just figured i ask first
  9. Woodwhore
    Woodwhore
    Mason NH
    Echo fixed, loose wire
  10. fezdawg12
    fezdawg12
    Elko, Nevada
    576 should be single lever control. My guess is linkage.
