Kiddie fire extinguisher recall
Discussion in 'The Wood Pile' started by Kevin in Ohio, Nov 27, 2017.
  1. Kevin in Ohio
    Kevin in Ohio
    This hasn't been publicized too much but wanted to let everyone know. Kidde has a major recall on most all of their fire extinguishers. Ones effected were made between 1973 to 2017. The ones with the plastic handles. You can go to their website and plug in your numbers as you don't need a receipt. If it falls into the recall the SEND you a replace in 10 - 15 days. I had 3 and went through the process and it was easy. We all should have them in our vehicles so check to see if you can get a new replacement.
    Here is the link: N130284 US Landing Page · Inmar Recall
    Pass the word around
    Eric VW, HDRock, MikeInMa and 7 others like this.
  2. tamarack
    tamarack
    paulina oregon
    Thanks for the info i have one thats new in the box still.
    Kevin in Ohio likes this.
  3. saskwoodburner
    saskwoodburner
    One of ours was a recall as well, they told the mrs 15-20 days until we receive a new one.
    FatBoy85 and Kevin in Ohio like this.
  4. yooperdave
    Thanks; I'll be sure to check the one on the boat as well.
  5. mikeward
    mikeward
    Long Island, New York
    Kevin in Ohio thanks for the info!
    I now have 4 replacements coming
    The website application is a pain to complete. Tough to get it to accept serial #.
    Worked on 2 of the extinguishers. Called the number listed and it was much easier.
    Got the first replacement yesterday
  6. Grizzly Adam
    Grizzly Adam Guest
    I am responsible for extinguishers at work. Only found one that was recalled, so I repurposed it.
    Timberdog, fuelrod, MikeInMa and 3 others like this.
  7. mikeward
    mikeward
    Grizzly Adam i was thinking of cutting top off and making giant wind chimes out if them.
    Question after you relived the pressure by squirting extinguisher
    Did you just unscrew top or just cut it?
    The replacement extinguisher came with a shipping label and a note to ship it back.
    I guess I could still keep it. But don't know
  8. Grizzly Adam
    Grizzly Adam Guest
    I used an abbrasive cutter to chop it. Also, on a side note, the extinguisher worked fine when I discharged it.
  9. mikeward
    mikeward
    Thanks for the info
    The cheap side of me says to keep the old ones and use them as well as the replacements
    Bet they would all work fine
    But I'd like to try and make something out of them also
    Will use grinder with cutoff wheel or bandsaw to cut
    Thanks
  10. CoachSchaller
    CoachSchaller
    Southeast Michigan
    hmm I will have to go check...
  11. Jon_E
    Jon_E
    Southwestern Vermont
    I have a couple of Kidde extinguishers that I have set aside for future disposal. I would never use those at work. I have over 100 extinguishers in my workplace and they are all Badger or Amerex #10 ABC units. Monthly checks and annual service.
  12. Grizzly Adam
    Grizzly Adam Guest
    Amerex is mostly what we have.
  13. FatBoy85
    FatBoy85
    Washington State
    Yep, looks like I bought some and need replacing. thanks Kevin!
  14. TurboDiesel
    Bump. for the newb's
    Summary: This product recall involves two styles of Kidde disposable fire extinguishers:
    • Plastic handle fire extinguishers
    • Plastic push-button fire extinguishers
    This Recall does not include Kidde Professional or Badger branded fire extinguishers. Units with metal handles/valve assemblies are not included in the recall.
    Follow These Steps:
    1. View the following links to determine if you have an affected model:
    • Plastic handle fire extinguishers: Open to view the Fire Extinguisher ID Guide (Opens in new browser window)
    • Push-Button Fire Extinguishers: Open to view the Fire Extinguisher ID Guide (Opens in new browser window)
    2. If you believe that you may have an affected model, before continuing, also use the Fire Extinguisher ID Guide (link above) to locate and collect your Model Number, Serial Number, and Date Code (if applicable). The Date Code is a 10-digit number printed on the side of your fire extinguisher, near the bottom. Digits five through nine represent the day and year of manufacture, and these five numbers are what you will need to proceed.
    3. When you are ready to proceed, select your unit from the list below. Note: If you have a push button model used on a personal watercraft such as a JET SKI®, be sure to select the personal watercraft option.
    Plastic Handle
    Push Button
    Push Button Watercraft
  15. Grizzly Adam
    Grizzly Adam Guest
    Found another recalled plastic handke at my last gun club meeting.
  16. Timberdog
    Timberdog
    Az
    1973?
  17. Kevin in Ohio
    Kevin in Ohio
    Yep, That's what it says.
    "Plastic handle fire extinguishers: The recall involves 134 models of Kidde fire extinguishers manufactured between January 1, 1973 and August 15, 2017, including models that were previously recalled in March 2009 and February 2015. The extinguishers were sold in red, white and silver, and are either ABC- or BC-rated. The model number is printed on the fire extinguisher label. For units produced in 2007 and beyond, the date of manufacture is a 10-digit date code printed on the side of the cylinder, near the bottom. Digits five through nine represent the day and year of manufacture in DDDYY format. Date codes for recalled models manufactured from January 2, 2012 through August 15, 2017 are 00212 through 22717. For units produced before 2007, a date code is not printed on the fire extinguisher."
  18. brenndatomu
    Hmm, that reminds me, I filled out the online form for replacing one at least 6 weeks ago...have not seen a new one yet...seems like maybe this needs a follow up...
  19. Timberdog
    Timberdog
    Az
    Yeah, it does say that—Just seems very strange that a 44 year old product would be eligible for recall or still in use. I was just wondering if they made a typo.
  20. Kevin in Ohio
    Kevin in Ohio
    I think it's safe to say there were lawyers involved and they were mandated to do so. Incredible cost involved and I'm surprised they could stay afloat.
    Timberdog likes this.
