Kickboard heater
Discussion in 'The DIY Room' started by bushpilot, Sep 17, 2018.
  1. bushpilot
    bushpilot
    Eastern Washington
    I am doing a kitchen remodel, and upgrading all insulation. As it all starts to go back together, I am considering adding a kickboard heater (electric) under the sink. Does anyone have one of these? If so:
    • My wife wants it under the sink, but I read online that they can be hot on the feet. But then, she likes warm feet, so what are your thoughts? (Likely will install a 1000-1500 watt unit.)
    • Is Broan OK, or should I consider a different brand? Why?
    • I am thinking 110v on it's own circuit, any reason to go 220v (which will be a little more complicated)?
    • I am thinking of using an internal thermostat, with a wall switch. Not ideal, but a clean install. What do you think?
    The reason for the heater is the kitchen has tended to be a little cold. The insulation and sealing will help a lot, but this should as well for little additional cost at this time.
    Thoughts?
    basod likes this.
  2. brenndatomu
    Broan is a good brand...120V should be fine on it's own circuit
    Chaz, Eric VW and bushpilot like this.
  3. Canadian border VT
    Put one in a condo 15 years ago. Because with the kitchen cupboards there wasn't a good way to add more regular baseboard hydronic in that area. It's worked fine, it's on its own thermostat 110 volt. The kitchen area is about 350 square feet.
  4. papadave
    Grab a hair dryer, set it on the counter, turn it on and VOILA. It's also portable (to an extent), so could be set on the floor for the tootsies. Done.:whistle::picard:
  5. shack
    shack
    Upstate NY
    ...you could get her a pair of hunting sox and furry slippers :D
  6. bushpilot
    bushpilot
    Eastern Washington
    Really?! Are you guys even married? :heidi:
    Eric VW, basod, brenndatomu and 2 others like this.
  7. basod
    basod
    Mount Cheaha AL
    Probably a couple times...
    We had one at my mom’s place that was piped in the hot water baseboard loop with thermostat run to a fan circuit.
    I’d run the electrical to an exposed jb under the sink with enough BX cable to the heater so you can eventually service the fan or t-stat someday
    And the counter mounted switch on a 20a double horizontal switch break the crossover and wire garbage disposal in a double gang with toggle switch for light over sink.
    bushpilot and brenndatomu like this.
  8. billb3
    I've only experience with hydronic ones - mostly mitigating annoying vibration noises from fans.
    One in a bathroom and no one ever complained about their feet being too warm.
    bushpilot likes this.
