Kerf too narrow to insert a wedge
Discussion in 'Chainsaws and Power Equipment' started by Yawner, Nov 10, 2020.
  1. Yawner
    Yawner
    Louisiana
    I felled an oak recently and when making the back cut, the tree sat on the bar and got stuck. The kerf on the back was so tight, wood to wood, I could not insert a wedge! I finally got a steel splitting wedge and got it hammered in there. What would you do in this circumstance? I am now considering getting an old axe head to carry but problem is, they're heavy! Just wondering if there is a technique to get a regular plastic wedge in, or what equipment to use. Of course, best technique is to read the canopy/lean of the tree correctly and prevent this!
  2. sirbuildalot
    sirbuildalot
    Mass
    When your cutting against the lean, you should be using a bore cut. This will allow the hinge and wedges to be set up correctly without worrying about the tree coming back and pinching your saw. You cut the back strap away at the end.
  3. Yawner
    Yawner
    Louisiana
    After the problem child, I did that very thing on two more trees right beside this one. I didn't assess this one properly, it really wasn't leaning; if so, it was barely. I think the problem was weight of the limbs on the back side; more were there than on the other side.
  4. jwebb
    jwebb
    Nashville, AR
    As soon as you have enough room to get the tip of wedge in is what I do and then palm it. Hope this helps
  5. Mag Craft
    Mag Craft
    South East Wyoming
    I have pinched my saw a couple of times when cutting up in the mountains. I have some steel cable that I take along and usually pull the tree over to the direction that I want.
  6. Breechlock1
    Breechlock1
    Always palm a wedge as soon as you can
  7. Mag Craft
    Mag Craft
    South East Wyoming
    Yep I agree.
    Breechlock1, T.Jeff Veal and Erik B like this.
