Keeping logs, how long before they go bad.
Discussion in 'The Wood Pile' started by JD Guy, Feb 15, 2025 at 3:12 PM.
  1. JD Guy
    JD Guy
    Upstate SC
    First off I did a cursory search here but found mostly folks talking about keeping rounds not logs for processing for firewood.
    Since Helene came through we have several Hickory, White and Red Oak and Cherry trees down or leaners. There is going to be a gracious plenty of wood and I would like to process it at my own pace. Since we do not consume a large amount of firewood each year ( it’s upstate South Carolina) I would like to put the logs and larger limbs on dunnage for staging.
    So, my question is how long do I reasonably have to get to these before I lose them? It seems prudent to me to only buck and process what we need every year to keep on the “3 year plan”. Will the logs not keep better whole than bucking and/or processing?
    Hate to waste premium wood:yes:
    Thanks all for your input and suggestions :D
    RCBS, Screwloose, wildwest and 4 others like this.
  2. Va Homesteader
    Va Homesteader
    Central Va
    I've had wood for 10 years before , the deciding factor in longevity is keeping it dry and off the ground. insects and decay don't like dry. some wooden houses are hundreds of years old.
  3. Eric Wanderweg
    Hickory in log form won't last down on the ground for much more than a year and a half, two tops IME. It starts going bad relatively quickly. Cherry will be good for a couple years and even if the bark sloughs off and sapwood starts to go, the heart wood will stay solid for several years. Red oak will be good for several years, white oak even longer, although like the cherry, the bark and sapwood will decay. So I'd tackle the trees in that order if it was me. Hickory, cherry, red oak, white oak.
  4. Chud
    Chud
    NC
    I would let the leaners stay in place unless they are a risk to people or property. Termites will get to work on most wood touching the ground here, so if I was going to store logs I would keep them off the ground. I’ve had a big piece of Red Oak log on the ground for about 3 years and it was growing fungus pretty good last summer. I will cut it up this summer to get whatever good is left in it. Willow Oak will decay faster than other Red Oaks when exposed to the elements.
    I’ve seen pine logs remain in good condition after years if they are kept off the ground.
    RCBS, Screwloose, JD Guy and 5 others like this.
  5. Locust Post
    It would keep much better split and stacked
    Bill2, RCBS, Timberdog and 9 others like this.
  6. stuckinthemuck
    stuckinthemuck
    Any time left to grow fungus or be exposed to insects negatively impacts the BTU’s you will get out of a given split for a given moisture content. It seems a lot of firewood sellers up here leave the logs stacked in log form for 3 months to a year and then process and sell as seasoned.what this does is allow the fungus to loosen the bark so when it goes through the processor. The bark just falls of and you are left with a clean split albeit with a couple less BTU’s from fungal growth. +1 on getting it split and stacked asap. If unable, get them off the ground. Logs with bark, touching logs with bark invite moisture, bugs and fungus. Health problems pop up unexpectedly. Having wood processed for more than 3 years ain’t necessarily a bad thing.
    RCBS, Eckie, Screwloose and 6 others like this.
  7. buZZsaw BRAD
    Oak and cherry heartwood will last for many years, Bark falls off and sapwood rots, but rest the meat is still good. Hickory has a much lower shelf life. CSS the hickory first as the rest can wait as long as you don't mind working with messy logs.
    Leave the learners as they may still put out leaves in the Spring if still alive.
    Good luck and be sure to post pics.
    RCBS, Screwloose, JD Guy and 3 others like this.
  8. brenndatomu
    My experience has been that cherry trees on the ground go bad quickly...the ants move in and decimate it.
    RCBS, Hinerman, Eckie and 9 others like this.
  9. Timberdog
    Timberdog
    Az
    Get them split and stacked off the ground and it won’t be an issue.
  10. JimBear
    JimBear
    In a perfect world with lots of time & help you could get the logs collected, cut, stacked & split as some have said.
    I understand thar you want to collect as time permits & then process as time permits.
    As others have said get that Hickory first the bugs will get after that quickly if left on the ground or in log form.
    Then the Cherry, I have had different experience with it than others. Here it seems the heartwood goes first & the sapwood lasts longer when left in rounds/logs.
    The Oak will last years, I have cut up oak logs ( 16”-20” ) that have been on the ground for 15-20 years & they had 1”or so of rotted sapwood but the heartwood was in great shape.
    RCBS, JD Guy, buZZsaw BRAD and 3 others like this.
  11. JD Guy
    JD Guy
    Upstate SC
    Ordinarily this would be my MO, but there’s just too much to deal with for me in a short time frame. Think I’m going to get the trunk logs and put on 4x4 or 6x6 to stage them. I appreciate the in put and will go after the hickory as a priority. I also have to build more rack storage or obtain some additional metal cages.
    Thanks All!
  12. Wouldsplitter
    Wouldsplitter
    Illinois
    If possible, stack the logs for a year or 2 then knock the bark off (using a grapple would be best) and they will last much longer. I had a pile of Honey Locust, Hackberry, Elm, and Basswood (linden) stacked off the ground 6 years and the logs were still good. Also had some cherry stacked off the ground 4 years (bark on) and it was all punky and rotten.
    IME The Hickory and white oak will be fine, (as long as they are off the ground). The Hickory bark will fall of after 1 year. The red and white Oak bark will come off in 2-3 years The cherry I would recommend knocking off the bark after 1 year. When the bark starts falling off you will need to move the whole pile to clear off the bark.
    I would also recommend using 2 sacrificial logs to lay the pile on. If you stack them on 4x4 they will sink in the ground and all the logs will be touching the ground in a few years.
    brenndatomu likes this.
  13. iowahiker
    iowahiker
    NE Iowa
    I would put down two white oak logs in parallel and stack the rest on top to be off the ground. Processing hickory first and cherry second would also be my choice. My neighbor logged and I had one season to take what I wanted. I stacked everything off the ground on white oak logs and then processed later. I finished processing two years later and lost no heart wood.
    Borers make a big difference here. Maple logs full of borers can go bad in less than a year or I have collected maple logs on the ground for two years in new condition, no borers. Borers carry fungus into the log.
    There was a mature red oak on the line between me and my neighbor so I exchanged the border red oak for a season of firewood harvesting, downed wood only. I did not leave any wood... (they got all the cull logs).
    brenndatomu and RCBS like this.
  14. RCBS
    RCBS
    Over here
    The order of rot on the ground goes like this where I am: Aspen, Beech/Maple, Cherry, Red Oaks, Hickory, White Oaks, Hlocust, Blocust, Hedge. I love oak for firewood but... I've grown weary of dealing with punky sapwood. If I can get em after the sapwood is gone I do, but usually that only happens if suspended. Some rot will intrude to heartwood on the ground in my experience. Locust can lay for years it seems. Whether they are on dirt or leaf litter seems to have an impact as well with the leafy logs going quicker.
  15. buZZsaw BRAD
    Cut safe and hoard on!
