Just a small job
Discussion in 'The Wood Pile' started by Backwoods Savage, Jul 5, 2017.
  1. Backwoods Savage
    Want to open up a trail through the pines (for taking tractor through) and needed to take down a tree or a couple of trees. Could have done with one tree but that would have been just a little tricky and taking down 2 other trees looked easier and would be a straight shot going through with the tractor so decided that was the way to go. Only got one down so far as there were a couple interruptions today but that is fine.
    So I got it down then cut into log length and hauled them out on the dray. Forgot to take those pictures... Sometimes I'm terrible with picture taking... I might take the other one down yet tonight but most likely tomorrow.
    EDIT: Yes, even got the ornery one on the tractor today.
    BZOR, RCBS, savemoney and 27 others like this.
  2. Well Seasoned
  3. HDRock
    Make a trail n firewood at the same time :yes: :saw::tractor:
  4. Backwoods Savage
    Actually I think I'll be using the logs to stack wood on as I really don't need the pine firewood right now.
    RCBS, TurboDiesel, Gark and 13 others like this.
  5. HDRock
    Well , you have a use for it anyway :stacke:
  6. Eric VW
    Lookin good. :yes: Take it easy up there Dennis! :thumbs:
  7. Chvymn99
  8. Jnb
    Jnb
    New Brunswick
    I always enjoy building trails through my wood lot for the tractor, and I think you made a good choice cutting two trees to make a straight trail. Straight trails are nice for a tractor in the woods, lots of bends in the trail doesn't work quite as well when pulling logs.
  9. Armbru84
    Armbru84
    Sparta, Michigan
    Good work Dennis! Hope things are drying up a little over your way.
  10. Mag Craft
    Mag Craft
    South East Wyoming
    Put that tractor to work. Very good.
  11. yooperdave
    Just cut the pine into rounds and if you ever have another GTG, chances are you'll find a couple nice ladies that will split and stack it for those signal fires you guys make down there!
  12. mikeward
    mikeward
    Long Island, New York
    Backwoods Savage gotta get some forks soon
    Is that bucket quick attach or pin on?
    Mine was pin on and I had to do some fabrication to convert
  13. Backwoods Savage
    It is a quick attach and yes, we do plan on getting a set of forks as they can come in very handy. Not yet decided on what size to get but I'll probably get some short ones.
  14. Backwoods Savage
    Got the second tree down but still need to haul it out of there. I'll wait for a cooler day as it is getting uncomfortable out there. So I put the tractor and atv away and turned on the air conditioner.
  15. mikeward
    mikeward
    I've got 42" the price for 48 jumped up a lot so 42 is good for me
    to get extra height I even put them on upside down at times!
    I couldn't live without 'em. For moving wood around they are priceless
    keep finding new uses.
    Lift rider mower to change blades and belts
    Work platform
    I try to put everything on pallets now
  16. mikeward
    mikeward
    Backwoods Savage , was thinking of you with the long straight pine trees
    Might try something like this. Will limit bending and rolling log to finish cut
    Not my tractor but I tried it and really worked well!
  17. yooperdave
    Hope that it doesn't shift to one side or the other while cutting.
  18. mikeward
    mikeward
    Actually worked really well.
    I wouldn't drive with it and tree has to be smaller diameter.
    I guess bigger tractor bigger diameter
    Must have hook on top of bucket too
  19. Backwoods Savage
    That could work nicely on small trees. Forks could work better though I think.
    Shawn Curry and Thor like this.
  20. mikeward
    mikeward
    Tried this before I had my forks. Small diameter trees only and worked well
    With forks you can lift BIG logs and cut them easily
    Forks will allow you to carry logs back to processing area but log length is limited by trail width.
