Jotul Oslo F500 owners V2
Discussion in 'Modern EPA Stoves and Fireplaces' started by JoeyD, Nov 18, 2022.
  1. JoeyD
    JoeyD
    I've had the Oslo set up in an existing fireplace going on 4 years now and have a question about adding a rear heat shield.
    I do get adequate heat now without the heat shield but was wondering if adding one would throw more heat out of the front. Right now, I'm not sure how much heat I lose heating up the fireplace cavity.
    If I burned 24/7 I'm thinking I would not see that much overall benefit since all the stone and block does put off some heat after a weekend of burning. But I mostly come home from work, light a fire and sometimes reload once before going to bed. This keeps the house comfortable all night until temps dip into the lower twenties overnight. I mostly wake up to a 65–68-degree house which is fine with us.
    I have a block off plate and the stove does not really sit in the opening except for maybe 2-3 inches.
    Any thoughts on this?
  2. Ohio
    Not Ohio
    I cannot help you with your question but. That is a sharp looking setup.:yes:
  3. moresnow
    moresnow
    Have you tried a small desktop size fan behind the stove?
  4. JoeyD
    JoeyD
    Thanks!
    We lucked out finding this house. Here is a wider view. We have 19' ceilings with a loft and fairly open floor plan. Two ceiling fans run 24/7 and some nice passive solar coming in the when the leaves fall.
    Heating and cooling this place is not as bad as thought it would be.
    Skier76, SimonHS and Ohio like this.
  5. JoeyD
    JoeyD
    That is a sterling engine fan and does an ok job of moving a little heat. I mostly have it because I like gadgets. :)
    I really don't want to see or run cords. Plus it's silent.
  6. JD Guy
    JD Guy
    Upstate SC
    Man, that’s a load of coals in there, must be hitting 600* plus! If we loaded ours up that much we would have to open up all of the windows and doors . I don’t know your location though so that likely makes a difference. Agree it’s a nice looking place!
  7. JoeyD
    JoeyD
    I mostly stay at or under 500 on my stovetop thermometer. This is just the way my setup likes to run it seems. I do occasionally get close to 600 but if I turn the air down this stove can control it from getting out of hand.
    I burn mostly 3 year seasoned oak and it coals nicely in this stove.
    SimonHS, JD Guy and theburtman like this.
  8. Canadian border VT
    Beautiful setup!! Dry oak does coal nicely in most stoves!!
    JoeyD and JD Guy like this.
  9. JD Guy
    JD Guy
    Upstate SC
    Yes, we have a Oslo 500 stove also. About 25 years old non cat but couldn’t tell you what version. On the coldest days we can get to 500 but usually 350-400 is plenty for us. We have a cathedral ceiling in this room but no open 2nd level, if we did I could easily see us at 500* We are burning well seasoned white oak currently too:D
    JoeyD likes this.
