Joining the Pellethood?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Gary_602z, Feb 1, 2014.
  1. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Okay I am thinking about taking out our zero clearance fireplace as we don't use it only about twice a year. I really like the looks of the Harman Accentra 52i insert which I believe you can get in a zero clearance?
    If so I have a few question:
    1: Good unit? Any cons?
    2: Will it fit? I have a 45"w by 34"tall opening to work with, would like to retain the current marble and mantle
    3: Venting? I think my windows are to close to meet code. Can I go up thru my current chase probably 25 ft.? Or up part way and then out?
    4: What would be a fair price for this new.(just the unit) I don't want to get taken but I realize the dealer has to make money also.
    5: Where is the credit department here in the pellet room?:)
    6: Are there any secret hand shakes?:)
    Thanks in Advance
    Gary
    will711 likes this.
  2. jtakeman
    The Harman 52i is a good unit, But it is a bit pricey. Another unit to look into in your search which should compete very well with the 52i is the Enviro M55 cast insert. I think there was a zero clearance version available. But can't seem to find it on their web site.
    As for the windows. You should be fine if you use an OAK as they cut the 4 foot clearance to around 18 inches IIRC. Or extend the vent to 4 feet above the windows could also be an option.
    Some of the more knowledgable folks will be around to help shortly. What ever you choose, Be sure to look at the rail kit for ease of removal. A tip is you can make your own and save a few bucks if money is tight. Keep us posted on what you find! :)
    will711 likes this.
  3. IHATEPROPANE
    IHATEPROPANE
    Is 4 feet above a window the correct clearance? Most of the stove manuals I have read have that clearance for below and to the sides....but above is 12"
  4. jtakeman
    You are correct, 12 inch above window or door opening is the spec distance.
    Guess I'm still under my brew quota! :emb:
  5. Gary_602z
    Gary_602z
    As our house has a wrap around porch I am limited on my clearances. The living room floor and the porch floor are at the same level and the ceiling on the porch is about 18 inches from the top of the windows. I will see if I can find a picture.
    Gary
    fishingpol likes this.
  6. Gary_602z
    Gary_602z
    How about going up and then out of the exterior chase?
    Gary
    jtakeman likes this.
  7. IHATEPROPANE
    IHATEPROPANE
    I think it could be that AWF high from the score earlier today :drool:
    slvrblkk and jtakeman like this.
  8. imacman
    imacman
    Denver, NC
    Jay, was this what you needed to see? It's in the regular owners manual:
  9. imacman
    imacman
    Denver, NC
    Welcome Gary. Us pellet burners are friendly folk......just install some form of pellet burner in your home, and you're in.......no secret handshake needed (besides the obligatory pics of the finished install, or even step-by-step pics.......just so we know it really happened).
    Oh, btw, if you like BEER, you'll make a LOT of friends here. LOL
    Scotty Overkill and will711 like this.
  10. slvrblkk
    slvrblkk
    Northampton, PA
    Well, there are "dues" involved that get sent to our Secretary and Treasurer.....we'll cross that path once the stove is installed ;)
  11. will711
    will711
    Pocono Mts.
    You might be able to also get a free standing unit in there , easier to clean and maintain IMO just my 2 cents :)
  12. jtakeman
    It would cost a little more in piping and detail parts, But it should be an option.
  13. Gary_602z
    Gary_602z
    Thanks for the input guys! I liked the looks of the Enviro also! Anything we do would have to pass muster with my wife as far as looks. Anything else be dammed!:)
    If we do it we would probably be doing a summer install. Is that a better time to buy?
    Gary
  14. jtakeman
    Yes, From Mid spring to summer is usually when you see specials and sometimes Manufacturers will have coupons for additional savings.
  15. will711
    will711
    Pocono Mts.
    The boss always has the final say;) Harman has a $250 off coupon good till March check with your local dealer .
    dylskee likes this.
  16. smoke show
    smoke show
    Pittsfield, Wi
    My dealer had a Christmas in July promo when I bought back in 2008. I won a ton of pellets and the stove included a ton. Also had half price venting during that time.
    dylskee likes this.
  17. DexterDay
    DexterDay Administrator
    Northeast Oh
    Both the M-55 and the new Accentra 52i are both nice stoves :)
    If you removed the whole fireplace? You could install a freestanding stove. Would be easier to service, normally has a larger hopper? And you could make the Hearth into whatever you wanted? Unless you wanted to leave it alone.
    Either way, if you like your wood stove heat, you should LOVE a pellet stove. My wood stove is nice, but I consider it supplemental heat. Where pellets are my Primary. I would never give up my pellet stoves. Even in dead of Winter, I load once a day. Even a Blaze King King can't do that when you need a high burn and it can't keep a constant temp and regulate it 24/7.
    Any questions, do not ever hesitate to ask. Many knowledgable people here that want to help and inform you of a good choice.
  18. Gary_602z
    Gary_602z
    Actually the fireplace itself is virtually useless for heating! We would like to keep the mantle and the marble tiles. We would probably use it as supplemental heat rather then primary.
    Gary
  19. Gary_602z
    Gary_602z
    New update! The wifey likes the looks of the Mt. Vernon E2 insert and the dealers says it would be an easier install also then the 52i. What few reviews I can find it seems to be a good stove. Anybody have any experience with the E2?
    Gary
  20. DexterDay
    Northeast Oh
    It appears the E2 allows the blower to vary it's output to maintain room temperature?
    Smokeshow has a Mt Vernon and can tell you better the Pro's and Cons. :)
    But overall they are a quality unit that crank the heat.. :thumbs:
    Gary_602z likes this.
