John Deere LT180 lawn tractor
Discussion in 'Chainsaws and Power Equipment' started by Stephiedoll, Sep 28, 2022.
  1. Stephiedoll
    Stephiedoll
    Omaha, NE.
    I was gifted one of these from my best friend Lefty. Hood is smashed and right now it does not want to turn over. I am jumping it from my pickup (not running) and first try it did turn over. Left and after returning with new fuel filter and a couple smalls it will not turn over with the switch. When shorting the terminals at the solenoid it will and try to run with a short spray of starting fluid. I was running fine last time he used it last year, but hood got smashed during his fire first of the year and it sits outside.
    Seeing if anyone has or knows of or has any manuals for this model. I can get one from JD for $39.00 but trying to be on the cheap until I know it has a chance of running again. I can work on it myself, just not much time/ambition to do so.
    Chvymn99 likes this.
  2. LordOfTheFlies
    LordOfTheFlies
    NY
    Here you go.
    I was gifted a John Deere X300 ride on mower and brought it back to life....although it started right up when jumped. I did have to replace the battery and I also replaced the fuel line. The rear left axle seal was leaking so I took the entire tranny off the mower (not hard) and drained the fluid, replaced the seals, and also replaced the 2 flat rear tires myself. Let me know if I can help in any way.
    This is actually the service repair manual.
    Jutt and Stephiedoll like this.
  3. Chris F
    Chris F
    Micksburg, Ontario
  4. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Thanks LordOfTheFlies , I think that is the same one I looked at but not a full manual. I'm sure my current problem will turn out to be simple as it did turn over when I first tried. Chris F I will look/join the site as it looks like lots of knowledge there. I know Lefty put a lot of money in the thing a couple years ago so should be in pretty good shape.
    Chris F and Chvymn99 like this.
  5. Chvymn99
    Another one I use and had active in for a while was: My Tractor Forum
    A lot of knowledge in there...
    Chris F and Stephiedoll like this.
  6. JD Guy
    JD Guy
    Upstate SC
    Try Weekend Freedom Machines it's a JD site for L&G tractor enthusiasts.
    Stephiedoll likes this.
  7. corncob
    corncob
    Somewhere in Lower Michigan
    Try replacing the battery and cleaning all the connections.
  8. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Thanks again, maybe I'll put an hour or two in it this weekend as it's still out at Lefty's. Should drag it home, but at the same time doubt I that it will be first on my list of things to do.
  9. LordOfTheFlies
    LordOfTheFlies
    NY
    It could just be old fuel. I just picked up a Honda HS928 snowblower and it started, then wouldn't stay running, then would burp, then wouldn't start......and I sat there and just took my time with a turkey baster and drained the tank. Put fresh fuel and it started right up. I'd check the spark plug too and make sure it's not fouled.
  10. Stephiedoll
    Stephiedoll
    Omaha, NE.
    I'm sure there's old gas in the tank. My goal right now is to is to get it to turn over with the key. I have to assume that one of the many safety switches is engaged or a switch problem. My priorities could be misplaced.
