Ive seen alot of **** in my life
Discussion in 'Chainsaws and Power Equipment' started by BuckeyeFootball, Mar 3, 2025 at 9:54 PM.
  1. BuckeyeFootball
    BuckeyeFootball
    But this takes the cake not sure if they were turds or balls of sawdust and oil wth.
  2. huskihl
    huskihl
    Every saw has them underneath protected areas. Oily sawdust vibrating around
  3. BuckeyeFootball
    BuckeyeFootball
    Well thats a relief. Ive never seen such a thing before.
  4. The Wood Wolverine
    I’ve seen them form while milling. Pretty common.
  5. brenndatomu
    So if someone says hey man, your saw has a lot of balls, it's not necessarily a comment about how much power it has... interesting, never personally seen that before!
  6. Ward Hoarder
    Ward Hoarder
    West Virginia
  7. BuckeyeFootball
    BuckeyeFootball
    I was highly concerned an animal had somehow got into my saw.
  8. buZZsaw BRAD
    X2
    Stihls don't vibrate enough like a Husky! :D
  9. huskihl
    huskihl
    I see you’ve never removed the white plastic on the clutch side lol. They are usually full of deer pellets bouncing around after a couple years use
    John D, MikeInMa, Husky Man and 9 others like this.
  10. brenndatomu
    Is that what does it, if you leave the cover in place a long time? I certainly don't take the cover off after every use, but have never seen the goat turds...
  11. JRHAWK9
    JRHAWK9
    Wisconsin
    same here. I've never seen those. Although I do remove the cover and starter and stuff and blow/clean everything up every year at the end of my cutting season. I also probably don't cut enough either, compared to some others.
  12. buZZsaw BRAD
    I take the clutch cover off often enough to either swap bars or chains. and have never seen that.
  13. metalcuttr
    metalcuttr
    western WA
    I have never seen them! I usually disassemble and clean after every use so maybe just don't have enough time to form. Also, usually cutting softwoods (Fir) with larger chips maybe that has something to do with it. If you keep seeing them, I prescribe a laxative bar oil!
  14. Screwloose
    Screwloose
    Interesting......new one on me.
  15. BuckeyeFootball
    BuckeyeFootball
    My covers only come off when I swap chains. Prob been about a year honestly because I was just touching the chain up but had a pretty big job with lots of dirty wood.
  16. JRHAWK9
    JRHAWK9
    Wisconsin
    Like -THIS- guy? :eek: 15 years and never been serviced.......not even cleaned the air filter, supposedly. :picard:
  17. buZZsaw BRAD
    Like a marketing plan of mine.
    Any time I sell wood to a new customer I comp them with a bottle of Ex-lax. Why? I want them to be regular customers!:D
  18. T.Jeff Veal
    I saw one the other night on the cover on the XS4910...
  19. metalcuttr
    metalcuttr
    western WA
    :picard:
  20. The Wood Wolverine
    Brad never lets us down.
