Wood stove pool heater is burning! Fire pit will be burning tonight. Pool temp was at 68 three hours ago
What is the temp now? I'd like to study that setup. I just want to heat a hot tub though. Thanks for putting up those pictures
74 after three hours of red oak fire. I get around 1 1/2 to 2 deg. per hour with good weather. They make a unit just for hot tubs. Look up Woodstovepool.con
Very cool man, I have been researching WSP for a while, was hoping to pull the trigger on one for this season but might have to wait till next year. May I ask how many gallons does your pool hold and what model WSP do you have? Great pics and awesome looking yard you have. Thanks for sharing.
We have the Silverdome (Lg) our pool is more like a very large hot tub. It measures 12x24 and is 4’ at the shallow end and 5 1/2’ at the deep end and has 9000 gal. We wanted something bigger than a hot tub but small enough to heat up easy. The stove will warm a 23000 gal. pool at 1 deg. per hour so we get from 1 1/2 to 2 deg. With the smaller volume.
Beautiful pool. I switched to a salt water system a couple years ago and will never go back. Love the wood fired heater. You can now bump the temp up to make it comfortable and get more use and a longer season. I had a homemade solar set up that worked pretty well.
I'm going to have to check this out. After a measly attempt at a solar setup on my garage I gave up and started cutting trees for more solar gain. Opened mine 2 weeks ago starting temp 66 yesterday it was up to 75. Substantial improvement after removing the big white oak.
That surely looks nice. We've thought about something like that but in the woods, we no doubt would have to have it enclosed. I also wonder about insurance coverage as they seem to frown on pools like they do trampolines.
NICE pool! Amy wants one but I need to open up some more yard before that can happen. Im just about ready for 2nd burn season myself. Picked up a new pellet stove for the cottage.
Not sure it was 4 years ago but I think it was $2400.00 delivered from Canada. It’s not that air tight so you loose some heat but who cares I have 23 acres of Red Oak to burn. It’s all stainless steel so no need to cover for the winter.
Lost a few deg. last night was at 72 this morning. Started the stove up and now at 84deg. happy wife happy life.
I'm hoping this email pastes right. Some of these pool heaters double as a pizza oven as well. Pretty slick... I contacted WSP back in Dec 2017 for some pricing, here's their response. Hello Mike Thank you very much for contacting Wood Stove Pools Wood Stove Pools builds the only 100% stainless steel wood burning pool heaters on the market manufactured right here in North America. Our stainless steel wood burning pool heaters are known as the WSP SilverBarrel (Mini), Silverdome (LG) & Megadome (XL). We also manufacture the only combo wood burning pool heater/ pizza oven in the world know as the WSP Pizza Silverdome (Lg+) & Pizza Megadome (XL+). That’s right, you can now truly enjoy the backyard cooking experience with your family when you purchase Wood Stove Pools wood burning pool heaters. These stoves will quickly heat your pool (over 1 degree per hour) while at the same time cooking a delicious pizza, roast, ribs, burgers, casserole dishes, which ever you desire. If you are not interested in cooking using Wood Stove Pools pizza oven, then no worries, we have options for you. As mentioned above and shown in the chart below Wood Stove Pools builds 5 sizes of Wood burning pool heaters. Regardless of your pool size we have the appropriate wood burning pool heater for your needs. The chart below shows a comparison of our stoves relative to your pool size: Stove Name BTU Suitable Pool Size (Gallons & Liters) Stove Dimensions Pizza Oven? Linear footage of stainless steel tubes (Heat Exchanger) 2017 Pricing End of Season 2017 Promo Purchase before Dec 31, 2017 SilverBarrel (Mini) 75,000 Up to 10,000 G/ 38,000 L 24” wide X 24” high No –grill could be added Equivalent to 60 linear feet $2000 $1800 Silverdome (LG) 125,000 up to 23,000 G/ 87,000 L 24” wide x 24” deep x 36” high No Equivalent to 100 linear feet $3100 $2900 Pizza Silverdome (LG+) 200,000 18,000 to 25,000 G/ or 68,000 to 95,000 L 32” wide x 28” deep x 54” high Yes 150 $4695 $4495 Megadome (XL) 250,000 23,000 to 29,000 G/ or 87,000 to 110,000 L 24” wide x 24” deep x 48” high No Equivalent to 200 linear feet $4100 $3900 Pizza Megadome (XL+) 350,000 27,000 to 35,000 G/ or 102,000 to 135,000 L 32” wide x 28” deep x 65” high Yes 250 $5695 $5495 All stoves come complete with everything you need to operate the stove, firebricks, chimney, inlet/outlet connection pieces, drain plugs, & a by-pass kit Note: As you can see in the above chart the pizza oven models produce better results, not just in our fleet of stoves, but they are the most powerful stoves on the market while also giving you the ability to cook delicious meals. If you need the extra output but do not want to cook using the oven then simply close the pizza over door and fill the fire box with wood and watch your pool increase in temperature by 1 degree per hour. We promise you one thing, over the course of the pool season you will be tempted to use the oven and you will be truly satisfied with the cooking results. Our track record speaks for itself with over 1500 Silverdomes and Megadomes sold worldwide and several hundred of our Pizza Silverdome & Pizza Megadomes sold. Wood Stove Pools was developed out of necessity, as we all know cold pools do not get used. We offer the most cost effective and fun way to heat your pool. Shipping: SilberBarrel (Mini) = $250 to a business or shipping terminal or $300 to your home Silverdome & Megadome = $300 to a business or shipping terminal or $375 to your home Pizza Silverdome & Pizza Megadome = $300 to a business or shipping terminal or $400 to your home If you live in Southern Ontario (Canada) or the Detroit Michigan area you can pick up the stove and save on shipping costs. When placing your order we can provide pick up details You have noticed our Stove’s initial outlay costs are comparable to a gas/propane heater installed and our operational costs is where your investment is returned to you. Depending on your climate you will require approximately 1-2 bush cord per season. A bush cord ranges from $250-$325. The average pool owner who uses a gas/propane heater pays $800 - $2000 per year on gas or propane. If you average that out over 10 years, it is a huge savings Your pool will retain its heat better if covered. Wood Stove Pools is also a dealer of the best Heat Retention blanket on the market. Provide us with your pool size and we can provide you with a quote. Any other questions or to place an order just ask. Sincerely Craig Wood Stove Pools 1-888-977-3472 [email protected] www.woodstovepools.com From: Frank Fekecs [mailto:[email protected]] Sent: December 15, 2017 8:58 AM To: Craig Kipling <[email protected]> Subject: Fwd: Woodstove Pools Contact Form this one is yours Thank you Frank Fekecs www.woodstovepools.com 1-888-977-3472 Begin forwarded message: From: WordPress <[email protected]> Subject: Woodstove Pools Contact Form Date: December 15, 2017 at 8:07:26 AM GMT-5 To: [email protected] Reply-To: [email protected] From: Mike Brennan <[textarea-128]> Name: Mike Brennan Email: Phone: Size of Pool Including Depth: Kidney shape, gunite construction from the 1960's. Approx 21,000 gallons Address including Postal Code or Zip: Massapequa Park NY, 11762 Message: Looking into one of your heaters to heat my pool. Approx 21,000 Gallons. Would like to know pricing/shipping on the model/models that would fit my needs. Thank you Virus-free. www.avast.com
