Issues with log splitter... engine first, now hydraulic pump
Discussion in 'Chainsaws and Power Equipment' started by Bossmode, Jan 29, 2021.
  1. Bossmode
    Bossmode
    Canada
    Howdy fella firewood getters!
    I got this old chinese made log splitter as a trade for 2 loads of firewood, appeared like a good deal at the time, started and ran good when first seen.
    Took it home and was able to split about 4 loads of wood, the weekend after, engine crank blew... ordered new engine and just arrived today, installed engine and then realized the hydraulic shaft is completely broken... so was not able to connect engine crank to the hydraulic pump...
    Because of it being a chinese log splitter from around year 2000 to 2005 I am having issues finding any parts or helpful info, I typed in part number of pump but can not find identical one, nor the shaft and adapter plate...
    Where can I find these broken parts, any leads?
    Thanks in advance!
    stuckinthemuck likes this.
  2. brenndatomu
    You should be able to just get a pump and adapter to match the motor you have and go...
    huskihl and triptester like this.
  3. Chris F
    Chris F
    Micksburg, Ontario
    Northern tool and other places will have what you need to replace the pump and get an adapter for the pump to the new motor.
    PA Mountain Man likes this.
