Is it normal to "hear" your wood stove drafting???
Discussion in 'The Wood Pile' started by Marvin, Oct 24, 2018.
  1. Marvin
    Marvin
    Huntingdon, Pa
    I noticed as the outside temps get lower and I fire up the wood stove I can "hear" it pulling air through the stove pipe and up the flue. It is by no means a roar. It just sounds like when it is windy out and you can hear a dull, steady wind outside your house. Almost like listening to a seashell. It gets quieter as I cut the air and disappears when I close it down to roughly 10-15%.
    While I may have a few pieces of cherry (what I've been burning) that are not quite under 20% MC, the majority of them are below 20%. The flue temp and stove pipe temp do not drop below the "good" range unless I let it burn out.
    I've heard of chimney fires making a "roaring" sound. Should I be concerned or am I just showing how green I am at this?
    Hammy, T.Jeff Veal, mat60 and 9 others like this.
  2. JPDavis
    JPDavis
    Prescott, AZ
    When's the last time you cleaned you chimney? If you've done it before the start of this burn season there's no way you're having a chimney fire this soon in. I'd check all the connections of my flue from the cap on down. I think you'll find what's making the noise by doing this.
    Hammy, T.Jeff Veal, mat60 and 7 others like this.
  3. billb3
    We have a stove whisperer.
    you can make ducts and tubes generate a noise with wind velocity, air rushing through an orifice will generate an ultrasonic noise that can sound like a rushing or low level roar. So yeah, it's possible to hear the wind going through the passageways in a stove..
    If you could get a passageway resonating you might make a tone .
    jo191145, Hammy, T.Jeff Veal and 10 others like this.
  4. Marvin
    Marvin
    Huntingdon, Pa
    I just installed a ss liner this summer so I would hope it's not gummed up already :hair:
  5. Marvin
    Marvin
    Huntingdon, Pa
    I would guess it is this. I think there is a pretty good breeze going outside. I hope that would be what it is anyway.
    Hammy, T.Jeff Veal, mat60 and 6 others like this.
  6. brenndatomu
    I can hear mine when the wind is blowing right...
    Hammy, T.Jeff Veal, Chaz and 7 others like this.
  7. Marvin
    Marvin
    Huntingdon, Pa
    I'm sure this has to be what is going on. I am just overly cautious about everything since I'm learning this stove:emb:
    Hammy, T.Jeff Veal, mat60 and 10 others like this.
  8. TurboDiesel
    Did you put a damper in the pipe between the stove and flue? If you have a really strong draft you would benefit from the damper.
  9. Tiewire
    Tiewire
    Missouri
    Mine will sound like a freight train when first lit with a cold flue and wide open but never heard anything after it is up to temp. I’m also half deaf so it could be.
    Hammy, T.Jeff Veal, mat60 and 8 others like this.
  10. Eric VW
    What?
    :whistle:
    :picard:
    Sorry Tiewire ..... couldn’t resist myself :emb:
    :yes:
    Hammy, T.Jeff Veal, mat60 and 12 others like this.
  11. saskwoodburner
    saskwoodburner
    Prince Albert, Saskatchewan, Canada
    My stove has a whistle sound coming from (what I believe) is the secondary air intake holes when it's very windy. No rumble/roar oranything else though.
    Hammy, mat60, Chaz and 7 others like this.
  12. Marvin
    Marvin
    Huntingdon, Pa
    No I left it out. I had one in the old stove pipe but figured my draft wasn't that strong. Maybe I'll have to put it back in....
  13. Marvin
    Marvin
    Huntingdon, Pa
    Maybe that's it. I noticed it after I first lit it this evening.
  14. Mag Craft
    Mag Craft
    South East Wyoming
    When ever I close mine down and get the secondarys going I get a little bit of a growling sound. No big deal but it does tell me when I have the air intake cranked down to a certain level.
    Hammy, T.Jeff Veal, Chaz and 9 others like this.
  15. papadave
    I heard mine last night. It told me it was time for a refill.
    Hammy, T.Jeff Veal, mat60 and 11 others like this.
  16. Marvin
    Marvin
    Huntingdon, Pa
    I may have to put the damper in. We just went nuclear here. I'm starting to get it cooled back down but it was a little hairy for a bit. I had the air cut off to about 25% and walked away for too long apparently :hair::hair::hair:
  17. Marvin
    Marvin
    Huntingdon, Pa
    I'm pretty sure my probe thermometer is ruined. I had the door wide open trying to cool the stove top after I closed off the air and got the flue temp down
  18. Eric VW
    :confused:
    We’re both in a learning curve Marvin :yes:
    But, I have a flue damper installed for just such an occasion.....:):handshake:
  19. saskwoodburner
    saskwoodburner
    Have you confirmed the air lever control plate is riding flush on its mating surface? I had that problem on my stove, and it would breathe like crazy.
  20. Marvin
    Marvin
    Huntingdon, Pa
    I have not but it seems to have pretty good control of the air.......other than user error a little bit ago not shutting it down soon enough.
