Insulating basement hot water pipes? Is it worth it?
Discussion in 'The DIY Room' started by don2222, Oct 19, 2019.
  1. don2222
    don2222
    Salem NH
    Hello
    Although there is no problem with pipe freezing.
    Last night we wrapped up the hot water lines in the basement and wrapped the seams with white wrap tape. We used heavy duty thick wall 3 foot pieces of heavy duty commercial grade fiberglass pipe insulation with the highest R value I have ever seen. R5.4
    We have an eco smart on demand electric hot water panel with a super stor holding take that the pellet stove heats to 80 Deg F overnight.
    Most of the hot water pipe is Pex but also wrapped up some copper which felt a lot warmer than the Pex!
    We used approx 14 Three foot lengths at approx $7.00 each
    Should this make a difference??
    stuckinthemuck and Jack Straw like this.
  2. ironpony
    ironpony
    Mid Ohio
    NOPE........
  3. billb3
    You might see a degree or so hotter at the faucet but not any sooner. The longer the run the more effective wrap roi. Same with gallons of water used. And if you're paying a lot to heat the water. I doubt you'd see anything approaching an immediate ROI if you paid someone to come in and only wrap pipes but DIY or if you already have a crew there for something else, maybe worth it.
    Same with the cold water pipes, although you might stop them from sweating and dripping on the floor in the Summer.
    Mitch Newton likes this.
  4. don2222
    don2222
    Salem NH
    Thanks for your comments!
    It was a DIY with my assistant so it cost approx $125 for the job so not too shabby. :)
    Need2Saw and Stephiedoll like this.
  5. ironpony
    ironpony
    Mid Ohio
    so if you save $1 a month you will break even in........................................10 years.
    keep us posted, I always enjoy your projects.
  6. don2222
    don2222
    Salem NH
    Yes I agree but It is paid for and I am thinking about retirement so switching from oil hot water to On Demand Electric was very costly, the lower cost of living will really help in the golden years! :)
    Below is the white covered foil tape we use for the seams!
    Venture Tape 1540CW Cold Weather ASJ Insulation Tape
    stuckinthemuck and schlot like this.
  7. don2222
    don2222
    Salem NH
    Hello
    My wife said that her first shower with the new pipe insulation that the shower water stayed warmer!!
    I knew the girls would notice!
    The shower is approx 30 feet from the hot water panel so that makes this job a complete success!!
    Thanks guys!
  8. Nitrodave
    Nitrodave
    Grayling Mi.
    the real test: in about a week, tell them you had to take all the insulation off to repair a small leak, and it was too much hassle to reinstall....... then wait for the first cold shower comments. :D
    LongShot, shack, DNH and 3 others like this.
  9. snaple4
    snaple4
    You will notice a difference between uses. It will hold temp in the pipe longer thus reducing water use between frequent uses.
    My pipes are in slab. 30 seconds with kitchen faucet off and the water is already going cold. Hate that they didn’t ins
    WiscWoody likes this.
  10. stuckinthemuck
    stuckinthemuck
    However small, you will also see a benefit in the summer.. waste heat from hot water will also affect your cooling demand if you run air conditioners at all. So you can add another $3 per year to ironpony ’s estimate.;) We heat our hot water with a superstor hooked up to our oil boiler year round. In the winter, the waste heat keeps the basement pipes from freezing unless the temps dip to the minus teens. Then we have to run the 3 FHW heating zones twice a day to provide some extra heat. I wrapped the pipes between my boiler and my superstor where I’m convinced that I get the most bang for the buck. With the boiler water around 180 degrees going to the hot water heater, I’d lose a lot of heat without that insulation. Agree with the assessment that the ROI wouldn’t be there if you paid someone else to do it. But with DIY, it’s probably worth it...
    Curious about your setup with the pellet stove heating water in the the superstor. Do you run a circulator pump and pipe between the two?
  11. don2222
    don2222
    Salem NH
    No connection from pellet stove to SuperStor, the hot air from pellet stove near the SuperStor just heats the water inside. No expensive heat pump needed! LOL
    stuckinthemuck likes this.
  12. yooperdave
    I'm wondering why you didn't use foam pipe insulation? Quite a bit cheaper.
  13. billb3
    They shrink at temps higher than most hot water is set at. You wouldn't want to lose any of that million dollar saving R2 now would ya ?
    yooperdave likes this.
  14. yooperdave
    I used them on the OWB lines on the inside of the house and have not observed any shrinkage.
    Agreed, the "R" value isn't too high (slightly below 2.5) but I noticed a difference right away in the temps at the heat exchanger on the water heater and the furnace.
  15. Canadian border VT
    Yes and if pipes sweat in summer less mold!
    Another thing I learned hard way:whistle:
  16. billb3
    I used them (tried) on 1/2 inch hydronic lines. They shrank. Shriveled up like a wiener in ice cold water. Ended up trying the wrong size fiberglass ones for 5/8 or 3/4, whatever the store had . I think the fiberglass ones were R4
    I've used them on cold water pipes and they do stop the sweating in the Summer. I've used them on the hot water copper pipes. The math for R2 doesn't support much.
    Faith can be an interesting object.
  17. WiscWoody
    WiscWoody
    NW Wisconsin
    That’s why I insulated my HW pipes, I just wanted to have some warm water in the pipes a bit longer so I wouldn’t have to run the water so long to wash my hands or rinse a plate. It does help in that way.
    yooperdave and don2222 like this.
