Installing the optional Harman P52i Air Adapter!
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Oct 5, 2014.
  1. don2222
    don2222
    Salem NH
    Hello
    Even though this fresh air adapter is optional, IHMO it should be mandatory not only the Harman P52i but any fireplace insert, to save pellets and heat and stop uncomfortable drafts created by drawing room air in from the cracks in the house to the burn pot! Here is why?
    With an additional 3" liner and chimney top, nice clean fresh air can be drawn into the burn pot using the Harman P52i Air adapter. When this is installed, Roxul (100% Fire Proof Insulation) can be placed on the damper shelf to keep warm heated air in the room from escaping up the chimney! ! !
    This stove is very big and quite heavy, has anyone carried it up stairs?
    Steps
    0. Remove stove from frame if old or in our case remove shipping bolt and seperate frome from stove.
    1. Remove original Air Intake flange
    2. Screw in top and right side self tapping bolts to hold hew air adapter where orig flange was mounted
    3. Must create new hole with self tapper on left side
    This is not easy since room blower is in the way.
    I found two choices here
    a. Remove room blower to get self tapper straight on and screw in.
    or
    b. Drilll pilot hole on angle, the get sel tapper in
    4. Drill two new holes to mount top of air adapter with self tapppers. this was staight forward.
    5. Mount 3" flange to P53i Frame for flex liner connection using white lytherm gasket supplied.
    6. run liner down chimney. (We tied 4" and 3 " liners together and did both at same time!)
    Use separate chimney top and make fresh air lower than flue exhaust chimney cap
    Screw fresh air liner to air adapter flange using self tappers. I sealed with silicone, but not neccessary.
    7. Add Roxul 100% Fire proof insulation to damper shelf and cut around flex liners to save room heat!
    8. Slide stove back in frame
    It is a little more work when doing the initial install but well worth it!
    Also a good update to save more pellets and stop drafting dirty chimney air amd/or warm room air into the burn pot!
    See pics - click to Enlarge:
    Pic 1 - Remove Old OEM flange
    Pic 2 - Using self tapper supplied, Cutting a new hole with room blower in the way!
    Pic 3 - New Rigid Air Adapter
    Pic 4 - Mounted Air Adapter 1
    Pic 5 - Mounted Air Adapter 2
    Pic 6 - 3" Fresh Air Falnge (Note flange can be rotated if liner comes down at angle!
    Pic 7 - 3" Liner coming down to P52i Frame for fresh air for burning!
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    Very nice Don! I love that kit. An OAK should be mandatory, especially for inserts that want to pull that cold air from the cold block/brick!
  3. don2222
    don2222
    Salem NH
    Thanks Dexter, that stove is 475 lbs!! However it was easy for the new Escalara Stair Cat! ! !
    wildwest likes this.
  4. DexterDay
    Northeast Oh
    Those things are awesome! ! I would love to see a video of it in action!
  5. imacman
    imacman
    Denver, NC
  6. krooser
    krooser
    Waupaca, WI
    Why buy a Stair Cat when I have a wife?
    SmokeyTheBear and imacman like this.
  7. Lousyweather
    Lousyweather
    we use lectrotruck's version.....
    http://www.lectrotruck.com/index.html
    Our first stair climber was an Escalera, but we found it to lack in durability when compared to the Lectrotruck. Just works better for us.
  8. Gasifier
    Cool, nice work don.
  9. jtakeman
    We use the skinny guy version with the manual truck. See if he can hold her back before the load crash happens. I once road a fridge down a flight of stairs. Its lucky I had the presents to hop on the darn thing and enjoy the ride. I never saw my bro inlaws eyes ever open that wide before!!
    These new fangled contraptions make life to easy these days!
  10. Lousyweather
    Lousyweather
    they are basically a necessity anymore, given how much these stoves cost, folks predilection towards litigation, workmen's comp claims, etc......just need a good way to get a 500 lb stove up a flight of stairs or two.....
  11. don2222
    don2222
    Salem NH
    Does the lectrotruck have forks to lift a pallet in and out of a truck?
  12. Lousyweather
    Lousyweather
    it works differently, Don.....you strap the stove to the dolly, wheel it to the back, angle back, then telescope it to the ground (it doesn't have forks, it has a platform very similar to a appliance dolly)...so, yea, you can lift it out of a truck, its what we do all year long. I never was a fan of the cable/crank setup on the escalera, but that's me,
  13. don2222
    don2222
    Salem NH
    Hi LW
    I see
    With the optional balance box, optional fork and winch and optional caster attachment on the LectroTruck and you got an Escalara!
    You do alot more than stoves, but the Escalara might be better for just stoves?
    Do you have a seperate fork lift?
  14. Lousyweather
    Lousyweather
    we only deliver stoves with the Lectro......several hundred per year....our personal preference is the Lectro.....did the Escalero for a few years as well, its just for us, lector seems to work better.....yea, we have forklifts, 6 of them, but don't deliver stoves with them at all....its tough to get the 8' wide lift thru the front door.....maybe if we drive faster on approach? :thumbs:
    DexterDay likes this.
