In the Woodshed......How long can it sit???
Discussion in 'The Wood Pile' started by Nordic Splitter, Jan 14, 2017.
  1. Nordic Splitter
    Nordic Splitter
    WNY
    Went into my woodshed today to take some time and restock a few of my designated wood are's...About half way through I came to realize that unless February & March are absolutely brutally cold....there is no way I'm going to use everything in the woodshed. Probably be left with about 4 face cords in the back of the shed. With that in mind...Should I rotate it out or just leave it and restock in front of it? How long can I let it go before getting concerned about it?...:)
  2. fox9988
    fox9988
    NW Arkansas 72717
    It should be fine inevitability
  3. Paul bunion
    Paul bunion
    Near forever as long as it stays dry.
  4. Viking80
    Viking80
    Norway
    I guess that's a matter of personal taste to some degree. But the wood should be good for several years as long as it's stored dry.
    I mean; houses built from wood lasts a while, doesn't they?
  5. Eric VW
    Yes, but with a slightly different set of conditions at play.
    But too, if that wood holding your house up got/remained wet, it would suffer the same fate as firewood left in the (intermittent) elements.
    You'll love whatever wood you have left over even more next year Nordic Splitter :yes:
  6. papadave
    I think I'll be in the same situation come springtime, and I've wondered whether I should use my energy to rotate it, or not.
    Me being me, I'll probably load some wood into the empty side, then restack the leftover in front of that.
    That wood was also leftover last year, so it's time for it to burn. All Oak.
  7. Nordic Splitter
    Nordic Splitter
    WNY
    My problem is, if I just restock in front of it....All winter long I'll be saying to myself.."I should have rotated it!":hair:
  8. woodsman416
    woodsman416
    New Jersey
    It should be fine....unless it's birch.
  9. Canadian border VT
    this is truly a good problem to have... my wood is too old and dry... it burns better hotter with almost no creosote :doh:
    it will be fine but if it makes ya feel better put it to front... go ahead... what type is it... when my great uncle passed he had some 10 yeor old stuff in sugar shack... it was still good. ..
  10. Nordic Splitter
    Nordic Splitter
    WNY
    Its a good mix of Silver Maple,Ash, Black Cherry, along with a little Oak & Hickory.:D
  11. billb3
    When I build a real firewood storage shed I'm either storing front to back or the back wall will also be a front.
  12. red oak
    red oak
    Yeah that's what I plan to do as well. Either not put a front or back on and just leave it open or put a door on both front and back.
  13. ansehnlich1
    ansehnlich1
    I have top covered wood outside that's been sitting for 5 years and it burns great! I've burned buried locust posts that were 50+ years old. I've also burned firewood that sat in a barn for better than 20 years.
  14. Backwoods Savage
    Wow. That could be a problem indeed. I would highly advise you don't leave wood inside a shed more than 50 years or so but in a pinch, you could go another 20 or so. No, I'm not being sarcastic; just telling it like it is. A wonderful problem to have.
  15. Nordic Splitter
    Nordic Splitter
    WNY
    So your saying my Grandsons who I don't even have yet can use it?....Haha...:)
  16. EnglishBob
    EnglishBob
    Upstate NY
    I'am in the same boat, so this season will see the all the wood being used in the woodshed then operation redesign will commence. Instead of using and refilling the whole shed which hold 6 plus cords, I will divide it into two down the center and use each half per year. I use approx 3 cord per season so it should work out close.:stacke: plus :stacke: = :woodsign:
    :uk: bob :uk:
  17. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Can you work down one side or the other and stick in a divider if need be do you can pull and refill with some sequence? I can pull from both ends on mine which is perfect. Worst case, just burn it and be very warm!!!! Kidding of course. Good luck
    gboutdoors and Backwoods Savage like this.
  18. billb3
    If they put you in a home before you use it all up. Put their names on the splits so they can't fight over them. LOL
  19. Chris F
    Chris F
    Micksburg, Ontario
    Red oak gets worms in it that continue to burrow and make sawdust years after being cut and split. I have some four year old oak in my basement right now and when I pick a piece up there's little piles of sawdust on the piece it was sitting on.
    I don't necessarily know if that's bad or not but it doesn't look too good.
    gboutdoors likes this.
  20. Backwoods Savage
    If the dust looks like this, nothing to be concerned about. PPB.
