im thinking of making a 275 gal oil tank in to a huge wood stove
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by gunny100, Jan 25, 2015.
  1. gunny100
    gunny100 Banned
    lebanon,pa
    IM thinking of making a 275 gal oil tank in to a huge wood stove to heat
    hoping io could get 10 to 30 wheel barel loads of wood in the stove
    so it burns for a week with out refiling it
  2. Gasifier
    I don't like to tell someone they can't without knowing their skills. But what are you planning on heating? How are you going to control the fire in something like that? What are you going to use for controls so that you can get long burn times. A week?
  3. gunny100
    gunny100 Banned
    lebanon,pa
    ill use a damper in the stove pipe
    ill close it down all most closed
  4. Gasifier
    Do you have any experience building wood stoves? Welding/fabricating? What will you heat with it?
  5. pappy88
    pappy88
    Missouri
    An 8 or 10" flue works good on that size fire box & don't forget the pics !
  6. JustWood
    JustWood Guest
    Friend of mine built one and had it in a 40x60 spray foam insulated shop.
    Had a waste oil drip system . Lined with fire brick up about 18".
    Kept a heavy ash bed in it.
    Never put mare than 3-4 chunks on a good coal bed.
    I'll tell ya that thing worked awesome and he never had a raging fire in it. I worked with him in that shop 1 winter at 60 degrees consistently at well below freezing temps outside.
  7. Locust Post
    I'm sorry to say, but it's not going to burn for a week and if you draw it back that far it's just going to clog up the chimney. I had a stove made out of an old oil tank in an old shop many years ago and it would put out the heat but also eat the wood.
    jetjr and pappy88 like this.
  8. jetjr
    jetjr
    Pa/Md line
    A buddy has a large home built stove in his shop. You could load it up as full as possible and I still don't think you would get super long burn times. I would think with that amount of wood it would be either an inferno or a chimney clogging smolder.
    JustWood what kind of burn times did he get? I mean did he ever load it up full to see, and if so how did it react?
  9. JustWood
    JustWood Guest
    JustWood what kind of burn times did he get? I mean did he ever load it up full to see, and if so how did it react?[/QUOTE]
    I never remember him putting more wood in it than you wood put in a regular wood stove . Seemed to work well that way.
    I did see him put some 8" rounds 3' long in as well as some long slabwood and some palletwood. But I never once saw it red hot or a raging fire in it.
  10. jetjr
    jetjr
    Pa/Md line
    I did see him put some 8" rounds 3' long in as well as some long slabwood and some palletwood. But I never once saw it red hot or a raging fire in it.[/QUOTE]
    I load my regular stove with big rounds and splits that are 26 inches or so. I'm just curious about the loading it to the brim idea.
