I'm not so sure I agree with their study.
Discussion in 'Everything Else (off topic)' started by Backwoods Savage, Feb 18, 2022.
  1. Backwoods Savage
  2. brenndatomu
    I didn't read the whole article, but I agree 100%, have thought this for a long time now...corn is for food, not car/truck fuel.
    JD Guy, In the Pines, Ron T and 11 others like this.
  3. stuckinthemuck
    stuckinthemuck
    Follow the money……
  4. lukem
    Corn is for eating and making bourbon....ethanol is for race cars....just like God intended.
    There have been lots of studies done on this. On average, it takes nearly as much energy to make the ethanol (fertilizer, planting, harvesting, refining, trucking) as you get out of it. There are some by products from the corn that help offset the energy consumption.
    I'm all for clean energy, but this isn't it.
  5. stuckinthemuck
    stuckinthemuck
    So should we burn ethanol to make electricity to charge electric tractors to plow the fields to grow the corn that makes the electricity?
  6. lukem
    Ummm....
  7. bogieb
    Nothing in that article that I haven't seen elsewhere - and many of those points were brought up before the mandate for mixing ethanol in with gasoline came into effect. It doesn't add in that vehicles get lower MPG using ethanol mixed fuels than if using pure gasoline either - which even the gov admits (article is about E85 - E10 is not nearly that high of a loss).
  8. Chaz
    Chaz
    Southwestern NY
    Perhaps there is hope on the horizon..
    I agree that ethanol from corn is not an efficient, nor necessarily "green" use of agricultural land.
    But scientists are working on ways to synthesize gas, and other fuels and chemicals used for plastics and such.
    Using renewable electrical sources.
    :cool:
    Can the world make the chemicals it needs without oil?
    After all, gas stores energy very efficiently.
    And perhaps our politicians should look at research before simply banning things.
    :mad::mad::mad:
    Just a thought.
    :whistle:
    Edit..
  9. Horkn
    Corn is horrible as a food source for most animals, because it's largely indigestible. If you process it, it can be turned into digestible food. If you process it it it can be turned into alcohol too. Used for different purposes. Ethanol or bourbon, whiskey...
    Prior to the EV, ethanol fuel was made in e10 and e85 to reduce dependency on foreign oil.
  10. Backwoods Savage
    Corn might not work for some animals but it is an excellent food source for many. Born and raised on a dairy farm I learned at an early age the importance of corn. It was used for cows, steers, and chickens. We filled silos with corn, ground corn for cow, chicken feed. Corn along with good hay kept the animals in good shape through the winters and we got good production from the animals which helped to put food on the tables. I have nothing bad to say about it. Shoot, it even makes good deer feed. I also earned a living by going from farm to farm grinding feed, using corn. But except for the corn cobs, we never burned corn.
  11. Horkn
  12. brenndatomu
    All in all, when you take production into account...I really, really, really doubt that.
    And then factor in the reduced fuel economy, all the fuel that gets dumped out due to going bad, all the carburetors that get replaced due to being ate up, all the OPE that gets thrown out/replaced due to ethanol related issues...its just a bad idea...and as was posted earlier, follow the money...someone has/is getting their pocket lined from ethanol.
    Bottom line, if government wasn't subsidizing it, we wouldn't have ethanol at the pump.
  13. TurboDiesel
    FIFY
    Farmchuck, Eckie, Chaz and 6 others like this.
  14. Screwloose
    Screwloose
    Problem is it employs a lot of people. You probably would first have to have a suitable product that most of them would find acceptable or you won't get support.
    Plenty of uses for the alcohol even power generation.
    Maybe better crops for growing biomass?
  15. Horkn
    Switchgrass, or better yet, algae from wastewater plants.
    MNWood, Screwloose, Chaz and 3 others like this.
  16. Backwoods Savage
    Yes. From the article:
    While it might not seem that your body digests corn, it is only the outer shell that stays intact as the nutrients are absorbed by your body. Corn provides dietary fiber, which helps to regulate digestion by softening the stool and promoting regularity of bowel movements.
    Screwloose, Horkn, Chaz and 1 other person like this.
  17. brenndatomu
    Yup, switchgrass, sugarcane, etc...and yes, there's tons of largely untapped potential from wastewater plant effluent!
  18. Chaz
    Chaz
    Southwestern NY
    :fart::fart::fart:
    You mean when we're not all full of chit.
  19. Horkn
    Exactly. But there's a lot less of corn that is digestible, compared to other grains.
    Screwloose, brenndatomu and Chaz like this.
  20. Chaz
    Chaz
    Southwestern NY
    Just not as tasty.
    :popcorn:
