I'm hosed, broken spark plug!
Discussion in 'Everything Else (off topic)' started by Unicorn1, Jan 19, 2016.
  1. Unicorn1
    Unicorn1
    Amarillo, TX
    I decided to change the plugs in my 04 tacoma but the #2 plug won't come out. I broke the end of my extension clean off inside the socket, removed it went up to 1/2" drive and the plug came out but the threaded portion didn't. :(:(:(
    1964 262 6 likes this.
  2. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Time to drill it out, I believe MasterMech has a good recommendation on helicoils.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Maybe a tap for reverse thread might grab it and pull it out. Start hitting it worth PB blaster now, I mean yesterday.
  4. Jeffrey Svoboda
    Jeffrey Svoboda
    Probably best to pull the head at this point and take it to the machine shop. Expecally if it is a overhead cam engine.
    Reverse thread anything won't work at this point. There's a reason the extension broke.
    MasterMech and 1964 262 6 like this.
  5. Unicorn1
    Unicorn1
    Amarillo, TX
    This is what I'm thinking, I don't want the debris from the easy out collecting in the cylinder.
  6. TurboDiesel
    It will still come out.
    as bob said, start with blaster. put the easy out in and tap tap tap with hammer. give it a left turn, tap tap tap, little more left turn, tap tap tap with hammer.
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Just spit Ballin, is the plug fairly exposed, as in room to work or is it buried under the cover gasket? If the head is aluminum maybe you could weld in a bolt that fits through the plug body. The heat from welding might loosen things up. And remember PB Blaster. ....
    1964 262 6 and brenndatomu like this.
  8. Unicorn1
    Unicorn1
    Amarillo, TX
    I've tried a straight shank extractor already and nothing. Valve cover is off but the head has these spark plug sleeves in the way. Well this has sealed my fate.:(
    1964 262 6 and TurboDiesel like this.
  9. Certified106
    Certified106
    In The Hills
    That stinks.......
  10. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Ahhh the 22re's grandson. damm hemi motors
  11. Eric VW
    I haven't been able to "like" any post on this thread 'cos it's so painful to see/read. Hate this for ya, Unicorn1 :headbang::headbang::doh:
    BCPLLC, 1964 262 6, walt and 3 others like this.
  12. Unicorn1
    Unicorn1
    Amarillo, TX
    Well, I removed the head and its at the machine shop. I still need to remove the front cover to replace the timing chain and followers etc. At this point it might be better to install another engine, this is/was way more work than I ever wanted to take on. I think I'll start a poll on if I can reassemble this motor mess. :) block1.jpg block2.jpg head1.jpg head2.jpg
  13. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I think you had more issues on that #2 cylinder than a spark plug.... while it's out have new valve guides/seals installed
  14. lukem
    Yup. This.
  15. bocefus78
    bocefus78
    Indiana
    That's not just a spark plug issue. Machine shop should fix you up. Got any pics of the gaskets? I agree with replacing the above...fix it right while it's apart.
    1964 262 6 and Eric VW like this.
  16. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Also have them check to make sure the head I'd flat, hard to tell but the spaces gasket ed areas between cyl. 1,2,3 look iffy. This has been a known issue with the bigger Toyota i-4 motors.
    MasterMech, 1964 262 6 and Eric VW like this.
  17. Deererainman
    Deererainman
    Union City Ky
    I have a 2002 Tacoma with the 2.7 4cyl. I remember the first time I changed plugs, they were tight. I've always put a dab of never seize on the threads for insurance.
  18. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Better yet, coppa-slip. Copper based antiseize for steel to steel.
  19. 1964 262 6
    1964 262 6
    williamsburg, ohio
    the difference in color of the one cylinder compared to the others implies some other problem. how many miles on motor? any oil use? performance change recently?
    Horkn, MasterMech, papadave and 2 others like this.
  20. Unicorn1
    Unicorn1
    Amarillo, TX
    160xxx miles, uses a bit of oil between 5K oil and filter change. I have a cel code for the egr????
    Horkn, 1964 262 6 and wildwest like this.
