iGnorAnT mAinTenacEn
Discussion in 'Chainsaws and Power Equipment' started by Greenstick, Aug 22, 2015.
  1. Greenstick
    Greenstick
    I have never been around chainsaw wizards like some on here are so I stumble along doing the best I can. Just doing some simple stuff today and hope you can give me a learning. Pics below are fair game to pick apart for what I am not doing right or need to do different so I can learn a nickels worth of free chainsaw learnin!
  2. Greenstick
    Greenstick
    20150822_151758.jpg Peach Nehi pop...best pop in the universe!
  3. Greenstick
    Greenstick
    I replaced the drive sprocket. Is the old one in pic shot or a spare worth keeping around and what does the wear on it tell you?
    Eric VW likes this.
  4. Greenstick
    Greenstick
  5. Greenstick
    Greenstick
    I replaced the bar as it was so sloppy it was time. Did the tune up kit 2 filters and plug.
    Eric VW likes this.
  6. Greenstick
    Greenstick
    The chain I took off just did a couple stump grinding jobs and I am not sure if this was a result of that or another issue. All cutters on one side are wore on sides other side is fine. Is it abuse from trying to scalp the ground or something else?
    Eric VW likes this.
  7. Greenstick
    Greenstick
  8. Greenstick
    Greenstick
    Top shows wear on side of cutter bottom is opposite side with no wear. This way all around the chain. Wussup?
    Eric VW likes this.
  9. SquareFile
    SquareFile
    somewhere
    Is your spur and chain the same pitch?
    Eric VW and mdavlee like this.
  10. Greenstick
    Greenstick
    Both are .325 if memory serves right.
    Eric VW likes this.
  11. Brush Ape
    Brush Ape
    Jonesboro, Il
    Stumps might have anything it it Green, even concrete or a pair of scissors. You hit something.
    You're right abut Peach Nehi dang that stuff is a weakness. Do you ever see Canada Dry Apple soda up there? There's some soda from Kentucky called Ale81 (A Late One), talk about good. Those Mom And 'Pop," sodas are way better than the big companies. So was Vess and Faygo. Really good pop.
  12. ohio log slayer
    ohio log slayer
    Lawrence co. ohio
    Not to steal Greenstick ' s thread, but since we are on maintenance, anyone notice that not all stihl bars have the grease hole at the end of bar. Are they sealed rollers now or what? How do u grease them properly?
    Oldman47 and Eric VW like this.
  13. Greenstick
    Greenstick
    Good question.
    Eric VW and ohio log slayer like this.
  14. ohio log slayer
    ohio log slayer
    Lawrence co. ohio
    I'm sorta a newbie also Greenstick to maintenance other than cleaning up a saw after sawing and sharpening.
    Greenstick and Eric VW like this.
  15. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Ale 8 is bottled right up the road from me in Winchester. I prefer Northern Neck Ginger Ale as it has no caffeine. Interesting thing is that the two companies were started within a year of each other.
    ohio log slayer and Greenstick like this.
  16. Eric VW
    I got nothin'!
    Except that a decent bar tip grease gun (cheap) works well on my Huskies....
    Check it out at your local TSC, ohio log slayer, Greenstick...
  17. Greenstick
    Greenstick
    Not sure if it works or not but a couple times a year I take the bar off and prop things up and nose it down in a old quart oil jug with the top cut off and marinate it overnight in bar oil.
    ohio log slayer and Eric VW like this.
  18. ohio log slayer
    ohio log slayer
    Lawrence co. ohio
    My 170 has grease hole but my 311 a big nada.:hair:
    Eric VW likes this.
  19. 94BULLITT
    94BULLITT
    Frederick County, VA
    I think the Stihl sprockets are pretty soft so they wear out quick.
    Stihl bars are not supposed to be greased.
    Oldman47, Greenstick and Eric VW like this.
  20. clemsonfor
    Stihl have sealed or dont need other lube...so they say.
    Some just shoot compressed oil type stuff in there...like pb blaster her something. I dont on the couple ungreasable stihl bars I have.
    ohio log slayer likes this.
