Ignition question for you small engine guys
Discussion in 'Chainsaws and Power Equipment' started by haveissues, Jul 5, 2015.
  1. haveissues
    haveissues
    Hudson Valley
    I have a tiller with a brigs vanguard 5.5 horse engine. It will run for a couple of minutes then die. After that, it will restart, run for 5 seconds or so and die again, loosing spark each time it dies. You can restart it right away and it dies 5 seconds later. Bad coil I assume?
  2. normanscag
    normanscag
    ohio
    Make sure you dont have spark first. What i tell people that says it runs 5 seconds and dies or alittle longer, is to spray brake cleaner in carb to see if your able to keep it running long, if so its a fuel issue like a gummed carb. Why i say this is becuase 90 percent of my calls are no spark issue. If it stays the same then possible coil. Please dont take this wrong, alot of people cant see the spark. Easy test with brake cleaner
  3. haveissues
    haveissues
    Hudson Valley
    I put a tester inline and the spark disappears as the engine dies. It goes from very bright blue to non existent. I'll try it though.
    rookie1 likes this.
  4. normanscag
    normanscag
    ohio
    Sounds like a coil good to here u have a tester
  5. ironpony
    ironpony
    Mid Ohio
    also possible bad condenser, cheaper than a coil
  6. rookie1
    rookie1
    I'd say coil but I would check the wiring also before I buy a coil.
  7. haveissues
    haveissues
    Hudson Valley
    I'll give the wiring a better going over. I did look at it quickly and tried disconnecting the kill switch just in case it was acting up.
    rookie1 likes this.
  8. brenndatomu
    Is this thing old enough to have points?
  9. haveissues
    haveissues
    Hudson Valley
    No, it isn't that old. The engine looks like it is from '96
  10. MasterMech
    Condensers disappeared from small engine ignitions 30 years ago. Well before Briggs started calling some of their engines "Vanguard". Always worth a look tho on engines that are so equipped.
    Sounds like the typical failure mode for a failing coil to me. A cool for that motor shouldn't break the bank.
    Horkn likes this.
  11. haveissues
    haveissues
    Hudson Valley
    That's kinda what I assumed. Turns out I was using a Briggs and Stratton spark tester. Didn't even know I had it lol. I was surprised the coil is actually close to $70.
    Horkn likes this.
  12. MasterMech
    Any aftermarket options?
    Horkn likes this.
  13. haveissues
    haveissues
    Hudson Valley
    It looks like there is a $20 mystery brand one on ebay. I think I'm going to try that since it is a tiller and it isn't exactly an emergency if it doesn't run. If it was a honda I could replace everything external on the engine for $70.
    MasterMech likes this.
  14. MasterMech
    I've had mixed luck with eBay stuff but real good results with stuff from the bigger companies like Stens and Rotary. They often have a guarantee behind the parts and you would be surprised just how often the parts are actually made by an OEM supplier.
    I still use mostly OEM stuff but when the asking price gets too high or the machine doesn't justify the cost, I don't hesitate to go aftermarket.
    Horkn likes this.
  15. old 040
    old 040
    Buckeye State
    better make sure your engine doesn't have a low oil shut down, check, and top off the engine oil first.............;)
    Horkn likes this.
  16. haveissues
    haveissues
    Hudson Valley
    First thing I thought of! This engine is really simple-only a few wires
    Horkn likes this.
  17. old 040
    old 040
    Buckeye State
    if i remember right on this series of engine, the low oil shut down wires are below the gas tank through the top of the engine and kinda hard to see, are you sure it doesn't have the shut down on yours?
    Horkn and haveissues like this.
  18. haveissues
    haveissues
    Hudson Valley
    You might be right. What I thought was some sort of ignition module is listed as part number 710305 and is a "oil gard" module (that is how briggs spells it. don't know if it is a typo.) I'll see if that module is grounding out the ignition. I first suspected a low oil shutdown but didn't see one so I incorrectly assumed it wasn't there. Thanks for the tip.
    Horkn likes this.
  19. MasterMech
    Certainly worth looking into. I forgot Briggs had engines with LOS :rofl: :lol:. Some LOS systems do indeed have a delay built into them that will allow the restart and kill it a few seconds later. Now that I re-read your OP....
    A dying coil will usually continue to play dead until it cools off.
    Nice call old 040 ! :yes:
    old 040 and Horkn like this.
  20. Horkn
    Why would Briggs add a LOS? My old@ss Briggs don't even need oil to run. ;). Lol
    rookie1 likes this.
