I have an old Grizzly Wood Stove,
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Rick Banwell, Aug 22, 2016.
  1. Rick Banwell
    Rick Banwell
    Kalkaska Michigan
    I am inquiring as to the lever on the right side bottom of the stove push & pull? is this an air damper under the fire brick?
  2. Unicorn1
    Unicorn1
    Amarillo, TX
    Probably, can you post a picture?
    WeldrDave and papadave like this.
  3. WeldrDave
    Hello Rick, Welcome to the Forums, glad to have you!:cool: As Unicorn said, can you give us a pic? :ithappened: It sounds like an air regulation/damper "but" do you have an ash pan in the stove? It could also be a clean out.
    Here's some info..
    Grizzly Wood Stove
    The Grizzly wood stove is an old model from a company that went out of business in the early or mid 1990s. They had previously been manufactured by the Derco stove company. Derco was based out of Michigan.
    Grizzlies were made in both freestanding and insert models. They had a good reputation for quality so it’s a shame that they went out of business like they did. I’ve heard of many boxes from the 70s still going strong. The Blazer insert model in particular was a workhorse. I’ve heard of people heating up past 3000 sq. ft. easily. You can tell you have a Grizzly by the bear logo imprinted on the doors.
    One common issue with the insert was the damper rod becoming detached from the damper plate. This can be caused by overheating the unit. Welding it is a possible solution but you’re dealing with solid iron so its definitely not easy. You may need to bend the rod to fit it properly.
    At one point RJM Manufacturing was a contact for old parts. You can find RJM Manufacturing by phone at 715-720-1794.
    HDRock likes this.
  4. WeldrDave
    You now have to fix your Signature, and add an XL to that bad boy!
    Unicorn1 likes this.
  5. Unicorn1
    Unicorn1
    Amarillo, TX
    Done-:)
    WeldrDave likes this.
