I got a poulan pro 18 inch gas chain saw
Discussion in 'Chainsaws and Power Equipment' started by firewood master, Jul 30, 2015.
  1. firewood master
    firewood master Banned
    pa
    I got a poulan pro 18 inch gas chain saw starts up very easy cuts good
    only thing i was cuting up a mulberry tree and the saw gets very hot
    and i let it cool for a day and it starts right up
    have any idea whay it gets so hot
    Pallet Pete, HDRock, wildwest and 3 others like this.
  2. Eric VW
    Welcome firewood master, glad you got here! :D
    Don't know too much about Poulan saws, plenty of experienced guys can chime in directly...
    Are you familiar with how this forum works, tho? Pics, Pics, Pics!:rofl: :lol::thumbs:
    TurboDiesel, wildwest and clemsonfor like this.
  3. HDRock
    TurboDiesel, wildwest and Eric VW like this.
  4. rookie1
    rookie1
    Is it a catalytic muffler. They get plenty hot.
    Oh welcome to the forum. We love pics!
  5. brenndatomu
    None of my saws want to run for more than 1 tank of fuel in this heat. Adjusting the carb didn't help much on any of them either
    wildwest, HDRock and Eric VW like this.
  6. Oldman47
    Oldman47
    Illinois
    Have you checked to make sure the cooling air passages are all clean? If you run more than a minute or two you are relying on that air flow to cool your engine. Also check if there is a summer/winter vent of some sort. On My old Stihl I have a shutter kind of thing that gets reversed for cold weather use. It dumps warm air from the cooling flow into the carb intake air path. That is intended to make the engine run warmer in the cold.
  7. clemsonfor
    A very dull chain , very restricted muffler and a carb running to lean? Just my thought?
    Eric VW, HDRock and wildwest like this.
  8. clemsonfor
    Thats not good!!! I can run gallons of fuel through! I cut a good bit in the summer. Thats 90+F around here usually. No trouble.
  9. TurboDiesel
    Welcome to the site firewood master
    glad you found us.
    the heavy hitters will be along soon. they will be glad to help
  10. Moparmyway
    Moparmyway
    New York
    Pump gas ?
    clemsonfor and Eric VW like this.
  11. brenndatomu
    Yeah, pump gas treated with ethanol treatment. I guess I don't worry about it much because I don't wanna cut wood for much more than a tank of fuel in this heat either! :whistle: :D
    concretegrazer and Eric VW like this.
  12. Moparmyway
    Moparmyway
    New York
    Unfortunately just about every case that I have seen of or heard of lately about machines getting hot and not starting have been ethanol related.
    Had saws right next to each other working the same area;
    - The VP fueled saws ran fine and started with no problems all day, re-fueling and all.
    - The pump gas with ethanol saws were erratic running if they started at all after stopping to refuel, plus the ones that did run in the 90+ temps had the operators chasing the tune all day .
    Some guys say ethanol aint bad and they dont have a single problem ..................... others loose their hair chasing tunes and problems, then pay extra for the canned fuel.
  13. MasterMech
    Brand-new saw.....
    Catalytic muffler plus a lean tune probably make it run hotter than you may be used to. If it starts and runs ok, I wouldn't worry too much about it.
    Sharpen the chain, if you only cut occasionally, canned 40:1 fuel may be worth a look.
  14. firewood master
    pa
    saw is all most new only 1 year old
    Eric VW, HDRock and Pallet Pete like this.
  15. brenndatomu
    Hmm, interesting. We have 91 octane E0 available locally, I'll hafta try some, see if that makes any difference.
    Moparmyway, Eric VW and Pallet Pete like this.
  16. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I have had several poulan saws they are pretty good if you open up the muffler and rip all the guts out. Those muffler cats the epa requirements are terrible imo... The saw simply can't breath. Next remove the carb caps and tune the saw. It will run very well after that. some of mine are passed on to family and friends and still going strong ten years later.
  17. rookie1
    rookie1
    At the city I work at we have our own fuel pumps. When stations were switching to ethanol we specified straight gas and held out for a long time before our supplier couldn't easily get it. During that time a lot of companies and other city's were having troubles. Ethanol is just plain bad for small engines.
    Moparmyway, clemsonfor and Eric VW like this.
  18. firewood master
    pa
    if i remove the muffler would that help
    Eric VW and clemsonfor like this.
  19. Cut4fun
    Cut4fun
    OHIO Redneck
    I still havent seen what model or a pic of muffler. :doh:
    Eric VW, rookie1 and HDRock like this.
  20. rookie1
    rookie1
    I'm not sure you would want to run it with no muffler. I have replaced them with non cat mufflers.
    Horkn, HDRock, Eric VW and 1 other person like this.
