How sharpe should the wedge on a splitter be? I keep mine at a good edge but not sharpe like an ax or hatchet. Reasoning is , when I come to limbs in the wood, I want to cut them more than push them into the wood deforming the splits IMO A sharp wedge will help a lot with stringy wood. It’ll cut instead of push All bets are off when splitting “gum” Just sharpened the hatchet(near knife sharp) Touched up the splitter wedge Used a flat bastard
Pouring rain here , 42° Tinkering in the shop Aired up the tires, checked the oil Sharpened the pickaroon too
Splitter hasn't seen much use lately, but I put a decent edge on the wedge a couple years ago. I like it.
Is that a Fiskars hatchet? How do you sharpen it? I use a file to take out the burs, then the Fiskars sharpening tool, but it takes forever to get a sharp edge.
Yes, Fiskars I used a bastard file Worked fine Not shaving sharp, but would slice a tomato & cut wood
Lol. I've never heard of one either. Now, I split a lot of elm, and it's stringy. I never bother with sharpening the splitter wedge. It seems to work just fine. IDK, maybe I should try the dull wedge first in some elm, then sharpen it and try it on the same elm and make a decision?
And we're back to my apprenticeship. "The cut of the file refers to how fine its teeth are. They are defined as (from roughest to smoothest): rough, middle, bastard, second cut, smooth, and dead smooth. A single-cut file has one set of parallel teeth while a cross-cut or double-cut file has a second set of cuts forming diamond shaped cutting surfaces"
We've split well over 300 cord with our splitter but have never touched up the wedge. It works just fine.
I had some stringy birch that the wedge cut thru, some is wood tough Figure if it’s cutting (not splitting) sharper helps Files:
Yea You have pretty good splitting wood . Bet it’s rare to have to run the wedge all the way down, then use a hatchet to finish it off I think some birch has some gum genes
Yeah I've had my splitter for 10 years and never touched the wedge. If it wasn't raining I'd go out and take a pic but I don't think it looks too bad.
I remember keeping the splitting wedge nice and sharp on a small electric splitter I used inside, years ago. It helped...
