Hydraulic oil change interval
Discussion in 'Chainsaws and Power Equipment' started by BuckeyeFootball, Oct 16, 2023.
  1. BuckeyeFootball
    BuckeyeFootball
    How often does eveveyone change the hydraulic oil in their splitter? The manual says 100 hours but that seems excessive.
    metalcuttr, brenndatomu and RCBS like this.
  2. theburtman
    theburtman
    Mine says to change the filter after the first 25 hours and I don't think there is any change interval beyond that.
    Chud and metalcuttr like this.
  3. RCBS
    RCBS
    Over here
    I'm still running the original junk I put in mine 5+ years ago.
  4. Warner
    Warner
    Yup a little leaked out when I changed the valve so I topped it off. But that last it. I believe I purchased it in 09.
  5. The Wood Wolverine
    I've changed mine once in 10 years.
  6. brenndatomu
    Naw, that's not excessive, unless you are running at an extreme high temp, or have some sort of contamination in the oil.
    I'd change the filter and run it, unless the oil looks bad for some reason.
  7. walt
    walt
    north central ohio
    X 2
  8. chris
    chris
    SE WI
    time to change mine. 1 because it sat outside for the last 3 winters and 2 because i need to install new valve, might just toss a bigger pump on it also along with the lovejoy. Nothing wrong with either but they are 20+ years old and would hate to go through the mess twice. been about 10 years since the last change and the oil is pretty dark. Doesn't smell burned though.
  9. BuckeyeFootball
    BuckeyeFootball
    I meant it seems like an excessively frequent interval, not long.
    brenndatomu and metalcuttr like this.
  10. FarmerJ
    FarmerJ
    Minnesota
    I’d say get an oil sample kit from caterpillar and send it in for testing before changing it.
    $13 includes the mailer to send it in and get the test results.
    metalcuttr likes this.
  11. Va Homesteader
    Va Homesteader
    Central Va
    mine is the original oil and is 20 years old , it's still clean looking , I change the motor oil every year and air filter every other year. and have had no issues or repairs yet.
  12. lukem
    As long as it doesn't look milky or smell burnt, run it. My splitter has to have around 500 cord through it. It feeds 4 OWBs heating 6 houses for the past 10-12 years. I changed the fluid and filter 1 time, spark plugs and air filter twice, and oil change once a year.
    Its about due for a refresh though, down on power and cycles noticably slower.
  13. RCBS
    RCBS
    Over here
    I'll add a note...I been wanting to change over to ATF, but haven't gotten it done yet.
  14. brenndatomu
    How many hours do you put on in a year?
  15. BuckeyeFootball
    BuckeyeFootball
    Depends on the year. Probably about 50 this year.
    brenndatomu likes this.
